Turnbuckle Lengths
- call-911
Turnbuckle Lengths
Does anyone know of a modern Titanium turnbuckle kit that I can use on an RC10 (stock wide front arms and stock rear arms) that I can still purchase and find replacement turnbuckles if I need to? I'll be using the innermost mounting points on both the front tower and rear bulkhead (base of wing tubes) to give you an idea of the lengths needed. I should've measured the ones I used on one of my builds before I put the caps on and popped them on. I bought a complete set for a B2 thinking they would work, but they're way too long and the threads would need to be cut longer most likely making a mess of them if I was going try to "fix" them with a die.
Keith C
- call-911
Re: Turnbuckle Lengths
Doh! I found the length I need for the rears after digging a bit, now I just need the wide stock lengths. Does everyone use Lunsford turnbuckles for modernized RC10s?
http://www.rc10talk.com/viewtopic.php?f=1&t=4104&hilit=turnbuckle
Keith C
yip, i have them on both my b3 and b4call-911 wrote:Doh! I found the length I need for the rears after digging a bit, now I just need the wide stock lengths. Does everyone use Lunsford turnbuckles for modernized RC10s?
Edwin
Hi, my name is Ed, and im a addict.
- Eau Rouge
- Been thanked: 5 times
FWIW, Lunsford t-buckles are 3mm which is heftier than original 4-40 Associateds. They are an optimistic fit in the original RC10 ball cups, to say the least, but they do fit I have my 1/12th scale car set up with them). Upgrading to a HD RPM or Losi ball cup would help, but it depends on how period correct you want to be.
- call-911
Period correctness doesn't matter at all. These will be on my Siebenelch car that has as many modern parts on it as possible. So what would the proper combination be? Lunsford turnbuckles and RPM or JConcepts ball caps?
Keith C
- templeofspeed
- Has thanked: 3 times
- Been thanked: 33 times
Jconcepts ball cups are pretty nice (and available in white!), plus not as fat as the RPM ends. IIRC the early big hex Lunsford and RCPS turnbuckles were 4-40 thread, then they all switched to 3mm thread when they went to a 3/16" square.
- Attachments
- jcends.jpg (99.69 KiB) Viewed 1602 times
- call-911
So what length turnbuckles are you using there? That's the same setup I'm using for hub carrier and rear bulkhead.templeofspeed wrote:Jconcepts ball cups are pretty nice (and available in white!), plus not as fat as the RPM ends. IIRC the early big hex Lunsford and RCPS turnbuckles were 4-40 thread, then they all switched to 3mm thread when they went to a 3/16" square.
Keith C
- call-911
Actually, by the looks of it the front setup you have is what I could use too. So any idea what lengths all those lengths are or what you bought?
Keith C
- templeofspeed
Sorry Keith, they're FT replacements for a CE or Team car. I've not measured them, they used to be available in a set...call-911 wrote:Actually, by the looks of it the front setup you have is what I could use too. So any idea what lengths all those lengths are or what you bought?
- 1354 Views
Last post by askbob
- 1227 Views
Last post by firebird1999us
- 994 Views
- 2692 Views
Last post by andymac0035
- 2171 Views
Last post by n20capri
- 1033 Views
Last post by Bubbleboy
- 1119 Views
Last post by PBR Allstar
- 474 Views
Last post by LTO_Dave
