quick & cheesy way to use Tamiya wheels
rc-stu
Post by rc-stu »
Here is a super quick and super cheesy way to put blackfoot etc. wheels on your RC10 if you don't have the adapters/ longer axles or longer nuts. this is good for a runner but clearly not for a shelfer or display car (it's ugly but it works well):lol: .
-mask around the holes/posts and fill the area with plastic epoxy:
-drill the back part of the hole in the wheel with a 1/4" bit to fit the rc10 axle.
-sand the epoxy smooth and flat.
-cut a slit for the axle pin.
-put a big washer (this is a body post thingy) on and use a an 8-32 x 1/4 Brad Hole T-Nut (available at your local hardware store). done! and ugly!
germanrc10gt
Re: quick & cheesy way to use Tamiya wheels
Post by germanrc10gt »
hi,
still have the same problem. i do have the crp adapters for the rc10 but the axles are too short.
what longer axles are you talking of? #? the longer crp nuts i have are only for the rc10 front axles,
they don't work in the rear.
adam lancia
Has thanked: 7 times
Been thanked: 42 times
Post by adam lancia »
rc-stu wrote:Here is a super quick and super cheesy way to put blackfoot etc. wheels on your RC10 if you don't have the adapters/ longer axles or longer nuts. this is good for a runner but clearly not for a shelfer or display car (it's ugly but it works well):lol: .
Nice work Stu! My only concern would be that without a locknut the right side may loosen off because of the axle rotation and orientation of the threads. I don't think it looks bad at all, pretty clean looking with the washer and brad nut on there :)
rc-stu
Post by rc-stu »
germanrc10gt wrote:hi,
sorry, i didn't specify. the longer axles are for the front only. for the rear adapters you have to use the extended nuts or you can use the adpaters and the nuts i used here.
adam lancia wrote: Nice work Stu! My only concern would be that without a locknut the right side may loosen off because of the axle rotation and orientation of the threads. I don't think it looks bad at all, pretty clean looking with the washer and brad nut on there :)
Simple fix: (you can do all 3 holes for looks if you want.) just drill a pilot hole and screw 'em in.
germanrc10gt
do you ahve a number or picture of that extended nuts for the rear. i've never seen those.
adam lancia
rc-stu wrote: Simple fix: (you can do all 3 holes for looks if you want.) just drill a pilot hole and screw 'em in.
DOH! :D
Users browsing this forum: No User AvatarGoogle [Bot] and 13 guests
