MIP Gearbox motor plate question?
Hi all,
Can Anyone help?? I have a MIP gearbox, but I'm not sure which motor plate fits it??
Is there one available or is it a case of making a standard one fit??
Any help would be great...
JIm
JIm
- Attachments
- MIP gearbox3.JPG (69.38 KiB) Viewed 1731 times
- MIP Gearbox 2.JPG (60.76 KiB) Viewed 1730 times
- MIP Gearbox.JPG (65.18 KiB) Viewed 1730 times
- Been thanked: 12 times
Re: MIP Gearbox motor plate question?
Te stealth motor plate should fit, here are the instructions:
http://www.rc10talk.com/viewtopic.php?f=7&t=2280
- carloco8
- Has thanked: 74 times
- Been thanked: 271 times
despite how people may feel about *sheldonshobbies* on ebay, they have the special MIP idler and diff gear replacements for this transmission if you need them. They cost a pretty penny, but they are out there!
idler gear:
http://cgi.ebay.com/MIP-32T-RC-10-RC10T-TRANSMISSION-IDLER-BOX-GEAR-AS-32_W0QQitemZ200198566637QQihZ010QQcategoryZ34061QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
and
http://cgi.ebay.com/Idler-Change-box-Gear-RC-10-10T-AS-32_W0QQitemZ200193131220QQihZ010QQcategoryZ34061QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
diff gear:
http://cgi.ebay.com/MIP-52T-DIF-change-Box-Gear-RC-10-10T-AS-52_W0QQitemZ200198566904QQihZ010QQcategoryZ34061QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
and
http://cgi.ebay.com/Differential-Change-Box-Gear-for-RC-10-10T-AS-52_W0QQitemZ200193129013QQihZ010QQcategoryZ34061QQtcZphotoQQcmdZViewItemQQ_trksidZp1713.m153.l1262
idler gear:
and
diff gear:
and
- Has thanked: 36 times
- Been thanked: 1318 times
i'll get pics up in a little bit to show you what i'm talking about, but from the pics you posted, i can see that your trans case is pretty much worthless because someone cut the posts off the right case half to mount a motorplate. at least one of them anyway. i can't see behind the spur gear to see if the other one is gone, too.
Hi there,
Thanks for the replies, Only one of the mounting posts is missing so hoping that the others are going to be strong enough...
Any pics would be great...
JIm
JIm
this is a thread from the scan archives about the mip change box..................
Thats great, but does anyone have a pic with it mounted to a motor plate??
That way I can see how/where to modify the standard plate...
Cheers
JIm
Cheers
JIm
you don't really have to modify the plate. what happens is when the plate is mounted to the case, it's turned counter clockwise slightly. so you have to drill and tap 2 new holes (above the original 2) where to rear chassis kickup/motorguard attaches to the motor plate.
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
and maybe have a look HERE hope this helps
Come and visit the stable
Hey Asso_Man....
Thanks, a picture tells a thousand words
That car is sweeeeeeet
I'll have to post a few pictures of my cars soon.... thought there not as nice on the eye as yours...
Thanks
JIm
Thanks
JIm
- Asso_man!
You could use a spacer for the missing one... And FYI, you will most probably need to mill the bottom of the motor plate to make it fit and that will wipe off the bottom hole for the screw that retains the gear cover. I took out my MIP tranny from the graphite car because it was interfering with the Robinson Racing rear adjustable toe-in arm mount, so I'll try to find some time between two diapers and take a shot for you...
- 539 Views
Last post by tiger1
- 23 Replies
- 4188 Views
Last post by sgirouard
- 1912 Views
Last post by SnoopMaxx
- 1416 Views
Last post by bearrickster
- 1612 Views
Last post by schmacher
- 1106 Views
Last post by RCveteran
- 680 Views
Last post by ThomasH
- 1379 Views
Last post by adam lancia
