2.2 wheels on a gold tub
- MelvinsArmy
- Been thanked: 11 times
I know this has been covered dozens of times before, but when I type it into the search I just get a bunch of stuff I'm not looking for.
What is required to put 2.2's on the back of a gold tub? I have B2 wheels already. Do I just need to find some B2 or B3 rear stub axles and different sized bearings?
- skunk.werkz
Re: 2.2 wheels on a gold tub
I think you should be able to use a 3/16 axle? and the correct bearings and you should be golden!
- Been thanked: 4 times
10T rears fit directly and just need the bearing that fits in the front one for 10t bolt right on.DON
- Has thanked: 36 times
- Been thanked: 1318 times
well, if your using the stock rc10 hub carriers, you'll need to get 4 3/16"x3/8" flanged bearings. if your using 10t hubs, get the same size bearings, but plain.MelvinsArmy wrote:What is required to put 2.2's on the back of a gold tub? I have B2 wheels already. Do I just need to find some B2 or B3 rear stub axles and different sized bearings?
i believe any of the associated 3/16" stub axles should work, although i've never tried them personally. i would just get a set of b2 mip cvd's. much more efficient.
This is from teamassociated.com's Early RC10 Tech Help Page:
How can I use the 2.2" buggy tires and rims?
In order to use the current wheels and tires you will need the following:
7378 3/16 axles
#9277 bearings (3/16 x 3/8 flanged bearings)
#7369 axle pins #7368 axle shims
7378 3/16 axles
- MelvinsArmy
- 735 Views
Last post by raserx08
- 612 Views
Last post by LowClassCC
- 2463 Views
Last post by aconsola
- 1412 Views
Last post by mtbnjim
- 1418 Views
Last post by pejota
- 2082 Views
Last post by Brat
- 982 Views
Last post by 67CamaroSS
- 1024 Views
Last post by Eau Rouge
Bing [Bot],
Google [Bot] and 3 guests
