fibreglass sheet for chassis's
Hi all
Does anyone know where I could get any fibreglass sheet? the stuff used for RC10 shock mounts, schumacher chassis's (back in the 80's)
any advice would be appreciated
Thanks
Scott
Thanks
Scott
- mrlexan
- Been thanked: 12 times
Re: fibreglass sheet for chassis's
Do a search for Fiberglass Reinforced Plastic FRP, Grade G-10.
www.gojammedia.com
www.gojammedia.com
Is this something you've used before? does it have the same look as the chassis's shock mounts I mentioned?
- highwayracer
- Been thanked: 6 times
Are you looking for the white fiberglass? If so, what thickness? I'm also looking for these.
- mrlexan
Yep and Yep...... color can vary dependent on the specific manufactuer, but they are all close.CATS wrote:Is this something you've used before? does it have the same look as the chassis's shock mounts I mentioned?
www.gojammedia.com
www.gojammedia.com
Try McMaster Carr, search their website. They have all kinds of FRP and phenolic sheets. http://www.mcmaster.com/
C+M Team Cobra also sells Black fiberglass and graphite sheets all available at Tower.
- mrlexan
Be careful with how some dealers use the term Phenolic. You might just end up with certain type of computer/PC board that you will find will be totally useless. Been there done that.
www.gojammedia.com
www.gojammedia.com
- PBR Allstar
McMaster Carr, search "Garolite" and look at "G-10" I just bought a few sheets of it, and it's the stuff you want! It's the same stuff m_vice used on a lot of his outstanding parts.
Just been on mcmaster and typed in garolite, 2 questions. 1) do I need to get opaque 2) what colour is the best match ( there are loads, yellow brown, yellow green?)
let me know, THANKS
let me know, THANKS
- PBR Allstar
opaque means it's a solid color, and wont let any light shine though, I bought black and off white. the black is very black and the off white is a little greenish. I don't think they have any translucent colors. The stock RC10 shock towers and stuff I believe are a natural finish (no added pigments) and come out a bit on the translucent side. check out this thread that m_vice posted, I'm not sure what color that is on the chassis, but it's G-10 from mcmaster carr.
http://www.rc10talk.com/viewtopic.php?f=4&t=5690
hope that helps some more.
- MOmo
Buddy of mine works for TAP PLASTICS. Im sure they can find alot of different materials. I know that he can get CF sheets. (thinking about trying to repr some shock towers etc in CF. Not sure I can get the thickness w/o paying an arm and a leg though.
http://www.tapplastics.com/stores/index.html?
MOmo
MOmo
Just an FYI guys, you can actually dye the green-tinted G10 type fibreglass sheets using clothing dye (such as Rit brand).
For example items like original RC10 shock towers can be dyed black quite easily
Guys, if you are ordering, can I just hitch hike a piece or two with your order? I've contacted several suppliers and they are not willing to send to Singapore...
So, I hope you can help me on this! Thanks!
My collections:
Nikko Brat, Nikko Dictator II, Nikko Thunder Eagle, Kyosho Pure Ten Nitro, Associated RC10, Associated RC10T, Associated RC10 Graphite, Associated B4, Tamiya Tamtech 1/24 Porsche 962C, Tamiya Striker, Tamiya TRF 501X WCE.
- 779 Views
Last post by AYKBOBCAT
- 20 Replies
- 2286 Views
Last post by 1300GT
- 772 Views
Last post by hkp
- 517 Views
Last post by RedScampi
- 454 Views
- 651 Views
Last post by Halgar
- 856 Views
Last post by robsdak
- 2337 Views
Last post by SScott
