will this be ok for a steering servo?
mcinque103
Post by mcinque103 »
will this be ok for a steering servo in my rc10?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPB45&P=7
Brandon G
Re: will this be ok for a steering servo?
Post by Brandon G »
Dont see why not. Metal gears (somewhat), ball bearing, small.... A little slow.
I would go after this: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJYT8&P=ML
This is what I run in my B4. Very fast!
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXXJ36&P=7
Bummer it is discontinued. I ran it in my ZX-5 too, makes more room for tight applications.
mcinque103
i need it to be low profile, but the futaba is pretty expensive. i see what you mean about the other one beeing kind of slow though.
mcinque103
actually, i've been using a futaba s3003 and that's even slower so is there any other reason it couldn't be used?
Eau Rouge
Post by Eau Rouge »
bngiles wrote:Bummer it is discontinued. I ran it in my ZX-5 too, makes more room for tight applications.
The replacement s9551 should be out any day now. Same size, same price and more torque and speed. :) A GREAT servo for any electric car application.
Brandon G
Post by Brandon G »
mcinque103 wrote:actually, i've been using a futaba s3003 and that's even slower so is there any other reason it couldn't be used?
If you have been using the s3003, than this will be a step up for you in size and performance. Go for it!
Brandon G
Post by Brandon G »
Excellent....
Chewbacca
Has thanked: 51 times
Been thanked: 108 times
Post by Chewbacca »
I have both a Hitec 77BB and a GWS IQ-500MG as low profile servos in use. I actually think that the GWS is a bit better.
I did not check the data or compare the Data to the futaba though.
*** POWDER - KING ***
wyldbill
Post by wyldbill »
i have seen guys run old s3002 and even s3102 for dirt oval super tiny and like 65 torque.
Chewbacca
Post by Chewbacca »
Here's my low profile servo setup:
standing low profile servo 7-cell conversion
I think my GWS servos are a bit better though.
