Tamiya Secret's Out 1997
Dangeruss
Has thanked: 437 times
Been thanked: 1440 times
Post by Dangeruss »
Tamiya letting their JACCS Honda Accord and Cliff Opel Calibra enjoy the limelight as they reveal a full page worth of Hop Up's in this ad from 1997:
TA03F: 1/10 4wd electric touring car released in 1996. Front motor version of Tamiya's third generation touring car. Molded ABS construction, open tub chassis and four-wheel independent suspension with fixed camber links over lower a-arms. Oil-filled plastic bodied coilover mini CVA II shocks with clip in spring spacers held in place by molded shock towers front and rear. Dual bellcrank steering with molded plastic center link, adjustable spherical tie rods and direct mount servo saver steering. Bevel gear differentials front and rear connected by a new single belt drive system. Plastic tipped dogbone axles led to 12mm hex drives. Single piece plastic wheels, rubber slicks and clear lexan racing body varied based on nine different body styles. Mabuchi RS-540 motor and full bushings included with each unassembled kit. 1997 Cliff Opel Calibra shown.
FF01: 1/10 Fwd electric on-road platform released in 1994. Based on the molded ABS TA02 platform. Four-wheel lower a-arm/camber link suspension, dual bellcrank, spherical ended adjustable tie rods, & direct mounted servo saver steering. Plastic bodied oil-filled coilover CVA shocks with clip in spring spacers and molded shock towers. Molded radio deck and rear bulkhead expension. Pinion and spur primary drive front mounted gearcase with ball differential, metal dog bones and 12mm hex drives. Single piece plastic wheels, rubber slicks and clear lexan body varied based on the 16 different body styles. The unassembled kits included a Mabuchi RS-540 motor and full bushings. 1997 JACCS Honda Accord shown.
