Ball Cups - FanRC?
- Has thanked: 32 times
- Been thanked: 4 times
Ball Cups - FanRC?
I thought I saw a post (or comment) at some points saying the FanRC ball cups are a great replacement for the cups included in all the re-release kits. Is anyone running those that can confirm they're an improvement? I used the RPM's on my RC10GT, which worked great, but I'm guessing fitment/clearance becomes an issue with those when used on the buggy. I've also seen mention of Schumacher ball cups working well, assuming you don't mind the look.
- RogueIV
- Has thanked: 2171 times
- Been thanked: 1114 times
Re: Ball Cups - FanRC?
The rpms are better if they fit but the fan rc units are pretty good. Way better than AE's reres
- juicedcoupe
- Has thanked: 273 times
- Been thanked: 2113 times
RPM's face clearance issues in the front shock tower and bellcrank area on buggies.
There are a few things that might allow you to use them, especially if used together.
Low profile ball studs at the shock tower and center link. Schumacher has a couple options. JC Racing has some as well but they don't have a shoulder. Don't use them on the steering links, they bind before full travel.
Using the DS/GT bellcranks, with the steering links mounted in the rear position.
Moving the camber links to the outer holes of the shock tower. Not ideal but it works. Likely need shorter turnbuckles.
Not using the thicker shock tower or Losi bellcranks. Either of these are tight on a buggy by themselves.
I'm wondering if the Factory Works ball-raced steering with the ackermann drag link solves the issue if running RPM? Regardless, I'll likely try the FanRC to see if they're any easier to deal with vs. the stock ball cups.juicedcoupe wrote: ↑Wed Jun 25, 2025 1:00 pm RPM's face clearance issues in the front shock tower and bellcrank area on buggies.
- Has thanked: 1134 times
- Been thanked: 3941 times
yes, our ackerman drag link will allow you the clearance you need. All of our thick towers are also pocketed to allow the ball joint to sit close to the stock position as well.
The FanRC ball ends are not as durable as the RPM, but are very close to the originals (not like the junk AE is shipping). They snap on tight and are a great fit.
Just the info I was after, and thanks for confirming your ackermann link plays nice with the RPM cups.GoMachV wrote: ↑Wed Jun 25, 2025 1:43 pm yes, our ackerman drag link will allow you the clearance you need. All of our thick towers are also pocketed to allow the ball joint to sit close to the stock position as well.
- 154 Views
Last post by TravelinTravis
- 1424 Views
Last post by DrumAnBass
- 2143 Views
Last post by R Cane
- 2194 Views
- 782 Views
Last post by frgna
- 1535 Views
Last post by jfharper
- 2241 Views
Last post by bully
- 1183 Views
Last post by JosephS
Users browsing this forum: RogueIV,
Tbot [Bot] and 2 guests
