inverted servo mount
rdnether
Has thanked: 4 times
Post by rdnether »
In order to get my steering linkage to line up well, I tried something new and inverted the servo
The obvious drawbacks are 1: higher center of gravity 2: servo is more vulnerable.
Any other thoughts?
Has thanked: 273 times
Been thanked: 2113 times
Re: inverted servo mount
Does the linkage clear through the full range of travel? If so, run it.
Several cars have the servo mounted like that.
1911Colt
Has thanked: 1792 times
Been thanked: 868 times
Post by 1911Colt »
It doesn't contact the body? It seems that it would.
rdnether
Post by rdnether »
juicedcoupe wrote: Mon Jun 23, 2025 10:16 pm Does the linkage clear through the full range of travel? If so, run it.
Thanks for the reply, linkage is clear.
rdnether
Post by rdnether »
1911Colt wrote: Tue Jun 24, 2025 7:40 am It doesn't contact the body? It seems that it would.
I am using the original RC10T body, and it doesn't contact. Surprisingly, it's not even close.
Thanks!
Chewbacca
Has thanked: 51 times
Been thanked: 114 times
Post by Chewbacca »
If that is a truck - no problem. For a buggy you can swap to a low profile servo. Then the linkage lines up nicely in a normal flat position.
*** POWDER - KING ***
Return to “RC10 Truck Forum”
Users browsing this forum: No User AvatarAmazon [Bot] and 4 guests
