Losi Pro SE Arm Question
I have a Pro SE with mismatched front arms. Looks like it has one JRx2 Arm and one Pro SE arm (broken). Since Pro SE arms seem hard to find, can I use a modern arm (like a XX or XXX) instead?
- highwayracer
- Been thanked: 6 times
Re: Losi Pro SE Arm Question
Unfortunately, the arms from the newer cars are too wide. Let me check to see what arms I have...I thought I had some for the pro se.
regards,
highwayracer
regards,
highwayracer
- mrlexan
- Been thanked: 12 times
I think I have one extra.... I want to say last time I looked at it, it was a bit different than the ones installed on my car. By that I assume there were two versions. You can have it if you like.
www.gojammedia.com
www.gojammedia.com
- bearrickster
Yes the Jrx 2 arms will work I have 1 single arm also let me know if you need it. I just bought a Se on E-bay it had XXX arms on the front he had to cut down the front bulkhead it worked but I would have cut it in the back he removed the mat. from the front so the arms are a little far back for the shocks.
- Attachments
- 100_2226.JPG (121.54 KiB) Viewed 1228 times
- Has thanked: 51 times
- Been thanked: 108 times
Just by looking at that pic above I am pretty sure, that those xxx arm are way too long. Ithink I have a pair of swept arm I don't really need. But I've seen front JRX-2 arms around evilbay often enough. The cool thing about the original front arms is that there ain't no left or right.
*** POWDER - KING ***
I know not cheap, but you might want to give THESE
a try. Indestructable rpm arms, those are also on my bro's Jrx ProSE.
- bearrickster
Yes they were quite wide the whole set up was scraped and replaced with new stock swept arms and new bulkhead I was just showing how the XXX arms fit on this car, or dont fit is more to the point they arent a very good idea on the Jrx cars. thats all.
- Brandon G
Merry X-mas:
http://www.ultimatehobbies.com/istar.asp?a=6&id=LOSA1013!1002
Maybe they actually have it?
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
I may have to drive over there and see....bngiles wrote:Merry X-mas:
- 891 Views
Last post by mrlexan
- 2297 Views
Last post by railey72
- 588 Views
Last post by soniccj5
- 1086 Views
- 1029 Views
Last post by oldskool
- 1153 Views
- 947 Views
Last post by SoloGraphix
- 873 Views
Last post by blubblood
Frankentruck and 4 guests
