In 1994 Tamiya rolled out a new highway hauler with their 1/14 electric Globe Liner. The new Semi gave hobbyists a second radio controlled big rig option with static model levels of scale realism just as the King Hauler that preceded it. The Globe Liner was built on a shortened aluminum 'Hauler c-channel ladder frame with molded plastic crossmembers and chassis rail brackets. A drop beam axle was held in place by a pair of functional leaf springs with undampened spring loaded shocks up front, all guided straight by an adjustable tie rod and draglink steering system with spherical ends and a direct mounted servo saver. Putting the wood to the 540 sized motor, drivers could shift through the gears with the included three-speed transmission that first debuted on Tamiya's 1981 Hilux 4x4. Power from the trans was funneled down a dogbone driveshaft to a pair of tandem axles, a bevel geared thru-drive backed by a bevel geared rear drive axle, all located by a set of radius rods, leaf springs, and quartet of spring loaded undampened shocks for carrying those heavy loads. Ten single piece chrome plated plastic wheels kept the 11.00x22.5 tires rolling while the rig was topped off by a superbly detailed Cab Over body bathed in chrome plating on the grille, side mirrors, exhaust stacks, airhorns, bumpers, fuel tanks and more. The electronics, radio gear and transversely mounted battery hid under the chrome ladened body while the rear of the frame received a functional fifth wheel that could hitch up to the flatbed, tanker, and box trailers that Tamiya sold separately. A Mabuchi RS540 motor and 40 bushings were included with the unassembled kit:
Tamiya Globe Liner
- Dangeruss
- Has thanked: 425 times
- Been thanked: 1405 times
- Lowgear
- Has thanked: 121 times
- Been thanked: 792 times
Re: Tamiya Globe Liner
I love the Globe Liner, and had one back around 2005-2007 that I painted candy apple red. I have a single small picture of it on a hard drive somewhere I'll need to look for one of these days.
It's wild to me that they came out in 94 as I'd guess it would be more like the late '90s if anything.
- 709 Views
Last post by mark
- 1032 Views
Last post by shodog
- 3220 Views
Last post by RCveteran
- 1320 Views
- 1549 Views
Last post by tamiyadan
- 4359 Views
Last post by MelvinsArmy
- 866 Views
Last post by aconsola
- 1053 Views
Last post by therigliveson
Users browsing this forum: jcwrks and 1 guest
