1/4” wheels on Teams car… what do I need?
- Has thanked: 25 times
Hi all
Picked up a nice Teams Gold car and was hoping to use a set of JConcept Hazard 1.7 and 1.9 wheels.
I have just realised the wheels are 1/4” but the car has 3/16” axles.
Does anybody know the best way to solve this? I think I have the rear sorted with a simple change of the hub carrier and switching universals, but am not sure about the fronts. Can anybody advise what parts I would need. Many thanks.
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2092 times
Re: 1/4” wheels on Teams car… what do I need?
The carriers are the same, just need the correct bearings.
After that, all you need are the correct axles, shims, and pins.
The fronts are the same.
- Dangeruss
- Has thanked: 425 times
- Been thanked: 1404 times
Yeah, what
said. Replace the 3/16 x 3/8 bearings in your existing carriers with 1/4 x 3/8 bearings, swap in your new axles, fronts fit without modification.
Thank you both for your replies. Parts inbound.
Next problem is finding 1/4" shims in the UK. I misplaced a few and cannot work out how to find spares here. Any tips? Could I go for 7mm (1/4" = 6.35mm).
- juicedcoupe
You can probably find these:vonmarshalll wrote: ↑Thu May 22, 2025 2:58 pm Thank you both for your replies. Parts inbound.
https://www.amainhobbies.com/schumacher-1-4x5-16x0.004-ss-atom-eclipse-steel-shims-8-schu4112/p754715
That is incredibly helpful!
Team Associated parts are actually rather hard to find in this side of the Atlantic!
Which is a problem, because I am loving this build and can see a few more RC10’s in my future!
- terry.sc
- Has thanked: 7 times
- Been thanked: 157 times
Available from any 1/12th specialist shopvonmarshalll wrote: ↑Thu May 22, 2025 2:58 pm Thank you both for your replies. Parts inbound.
https://zen-racing.co.uk/crc/1640-crc-1-4-shim-set-20.html
https://zen-racing.co.uk/schumacher/5798-s-steel-shims-1-4x5-16x0004-ss-at-ecl.html
https://zen-racing.co.uk/search?controller=search&search_query=1/4+shim&submit_search=&manufacturers=excelerate
- Dangeruss
They're hard to find on this side of the Atlantic too. Associated isn't providing parts support for their re-releases like they should be.vonmarshalll wrote: ↑Fri May 23, 2025 2:39 am Team Associated parts are actually rather hard to find in this side of the Atlantic!
So I have decided to use a set of the chrome Halsey wheels up front with the knobbly tires and the standard rear wheels.
The fronts have a black main wheel with the chrome outer and the rears are ivory with chrome.
Am I right in thinking the RC10 wheels take dye well and that I can make the rears match by dying them black? Or are they an ABS and not nylon?
- juicedcoupe
The white wheels can be dyed, or there is also a chrome rear wheel.
- Dangeruss
Again... what
said
Associated part # 6396
And available in the UK... https://www.modelsport.co.uk/product/team-associated-jay-halsey-rc10-rear-wheels-chrome-1368430
Chrome wheels all around would look nice.
Thanks I was sure I had seen them somewhere.
Great to know they take dye though.
The Dhawk look lovely too.
Hi I have been looking at Tamiya Sand Scorcher / Frog rear wheels and wondering how to use them on 1/4" axles. I came across these from CRP...
https://www.ebay.co.uk/itm/235522038636?_skw=rc10&itmmeta=01JWPPD9V4VNSWBS8N1STGF9NM&hash=item36d6351b6c:g:CGgAAOSwRyRbHCIw
As far as I recall the Blackfoot wheels had the same hub as the Scorcher so I think I can use this. Does anyone know if I can?
- juicedcoupe
I have those on one of my RC10 truck conversions, with Monster Beetle wheels. They don't have the barrel nuts, so you will need to source them separately.vonmarshalll wrote: ↑Sun Jun 01, 2025 5:35 pm Hi I have been looking at Tamiya Sand Scorcher / Frog rear wheels and wondering how to use them on 1/4" axles. I came across these from CRP...
- Dangeruss
Juicedcoupe is correct, but don't underestimate the difficulty... they're not a commonly available size.juicedcoupe wrote: ↑Sun Jun 01, 2025 5:42 pm They don't have the barrel nuts, so you will need to source them separately.
- 1553 Views
Last post by RC10th
- 414 Views
Last post by mikedealer
- 545 Views
- 780 Views
Last post by HS-YZ250
- 3004 Views
Last post by LoboNYC
- 1071 Views
- 23 Replies
- 3119 Views
Last post by NickTheGreek
- 2259 Views
Last post by Synergy
