RC10 RPM Ultramold
Lavigna
Has thanked: 1100 times
Been thanked: 1419 times
RC10 RPM Ultramold
Post by Lavigna »
This is a full RPM Ultramold made from all new parts. Everything is OG. I've got it pretty close to where I want it, just a few changes and additions to go. I'm also deciding on a body.
To me, these cars never look right with the Stealth cases, so I modified the plastics to fit the RPM transmission. I'm not sure if I will be adding more electronics as it looks so clean without. The no tire look is growing on me.
TRX-1-3
Has thanked: 2090 times
Been thanked: 1005 times
Re: RC10 RPM Ultramold
Post by TRX-1-3 »
I can understand the no tires thing. This is such a phenomenal piece. However, deep down, you know you gotta put tires on it. Or, at least, two "O"-rings per rim, as I've seen lately. :lol: :mrgreen:
Boggling of the mind occurring (due to the incredibleness of the build)
DSaw78
Has thanked: 173 times
Been thanked: 50 times
Post by DSaw78 »
Amazing! Everything you build :shock:
Chewbacca
Has thanked: 51 times
Been thanked: 114 times
Post by Chewbacca »
WOW, just WOW :shock:
Now may I suggest the Losi Jrx2 Pro SE body for this build? I believe the ultramolded was actually intended for that body.
*** POWDER - KING ***
Lavigna
Post by Lavigna »
TRX-1-3 wrote: Tue May 06, 2025 8:22 am I can understand the no tires thing. This is such a phenomenal piece. However, deep down, you know you gotta put tires on it. Or, at least, two "O"-rings per rim, as I've seen lately. :lol: :mrgreen:
Thanks buddy! Yes, I went back and forth on a few tire options and wasn't sold on any. I thought it looked good just rims for now, but I will have to chose something.
Question - Do all the HPI 5 star rear rims for buggies have a smaller diameter? The tires I wanted to use on the rear didn't fit because the rear rims are a smaller diameter.
Has thanked: 1133 times
Been thanked: 3930 times
The era correct hpi wheels are all 2.0. They later made some 2.2 I believe for the Kyosho super nitro cars which would likely have the correct offset but are a 12mm hex and would not be era correct. Check part number 3032.
Has thanked: 365 times
Been thanked: 478 times
Chewbacca wrote: Tue May 06, 2025 9:48 am WOW, just WOW :shock:
That's correct
RogueIV
Has thanked: 2166 times
Been thanked: 1114 times
Post by RogueIV »
GoMachV wrote: Tue May 06, 2025 12:08 pm The era correct hpi wheels are all 2.0. They later made some 2.2 I believe for the Kyosho super nitro cars which would likely have the correct offset but are a 12mm hex and would not be era correct. Check part number 3032.
I have a super nitro, I can pull a wheel later and get you measurements if you'd like.
ZED32
Has thanked: 167 times
Been thanked: 247 times
Post by ZED32 »
Wow, absolutely stunning :shock:
Lavigna
Post by Lavigna »
Thanks for the information. It looks as though those wheels may have a different finish from what I currently have. More smooth unlike the rough finish of mine.
It may be worth a try though.
Lavigna
Post by Lavigna »
I have a beautiful painted Andy's Pro Arrow body that I'm going to see if it fits. If not, the SE body will be the choice.
MarkyDents
Has thanked: 1809 times
Been thanked: 643 times
Post by MarkyDents »
Stunning build as usual dude 8)
I really do like the Pro Arrow idea, wasn’t there a Hot Bodies body for Losi that was out during the same time as the Stealth Fighter and Stealth Bomber for the RC10 that was sharp looking piece ?
I’m wracking my brain trying to think of the name of it….
Hey Cru ! Go balls out 8)
jcwrks
Has thanked: 171 times
Been thanked: 393 times
Post by jcwrks »
The RPM 10T front spindles are a nice touch.
The TX SKUNK
Lavigna
Post by Lavigna »
jcwrks wrote: Wed May 07, 2025 8:15 am The RPM 10T front spindles are a nice touch.
Yeah, thanks. It's an upgrade to the upgrade.
Has thanked: 3728 times
Been thanked: 1987 times
Looks awesome. How do these compare weight-wise to a regular buggy? I would kinda guess lighter but it's kinda hard to imagine since I've only had experience with much smaller amounts of RPM material. Just curious.
Users browsing this forum: No User AvatarArexera [Bot], User avatarDangeruss, No User AvatarGoogle Adsense [Bot] and 3 guests
