Xxt graphite plus runner
- Charlie don't surf
- Has thanked: 355 times
- Been thanked: 470 times
Re: Xxt graphite plus runner
What are you planning on doing with it? XXt CR Graphite plus is a very capable vintage race platform. Transmission cases are weak spots, Jeff at Factoryworks.com makes a very cheap.trans brace tab that helps safeguard the cases (unless the T plate breaks too....and they can.... then both are trashed)
the old bulkheads are prone to failure too, Sabulatech makes molded replacements that all of us use, they're cheap too. Jose Zayas at Z3DRC makes a handful of 3D printed goodies including 12mm front rim adaptors so you can run easy to find Jconcepts 12mm hex T6.1 wheels, Associated SC10 12mm rear aluminum hex set do the same in the back. The hydradrive slipper that they came with leak all the time, B4 slipper plates drop right in on the hydra shaft as do Associated spur gears. Horizon Hobby still makes the shock cartridge sets at $4.99 but you can rebuild the ones you have unless the hex or threads are trashed. DPRC.com makes other losi specific re makes, but the gold shock shafts are wayyyy to unfinished...like they forgot the polish phase. Shelf parts only as of now...too bad too. Boki racing makes a very very nice remake shell (I think the 8017 is the correct CR shell). Any stripped out plastics or trans case holes etc...replace the 4/40 screw with a 3mm screw (I would tap with 3mm first on a graphite part) and instant fix, this includes ball studs-
What else?
What else?
Factoryworks.com has a great carbon fiber brace for about $20! DPRC has the rear CR type Tplate Milled PA66 nylon for $24. Don't sweat it!
- RogueIV
- Has thanked: 2130 times
- Been thanked: 1096 times
I'm just saying, I made the wheel adapters first. If you have a 3d printer then you can make them for free. https://cults3d.com/en/3d-model/game/12mm-jconcepts-mono-wheel-bearing-adapter-for-older-losi-trucksCharlie don't surf wrote: ↑Thu Apr 24, 2025 5:40 am What are you planning on doing with it? XXt CR Graphite plus is a very capable vintage race platform. Transmission cases are weak spots, Jeff at Factoryworks.com makes a very cheap.trans brace tab that helps safeguard the cases (unless the T plate breaks too....and they can.... then both are trashed)
the old bulkheads are prone to failure too, Sabulatech makes molded replacements that all of us use, they're cheap too. Jose Zayas at Z3DRC makes a handful of 3D printed goodies including 12mm front rim adaptors so you can run easy to find Jconcepts 12mm hex T6.1 wheels, Associated SC10 12mm rear aluminum hex set do the same in the back. The hydradrive slipper that they came with leak all the time, B4 slipper plates drop right in on the hydra shaftScreenshot_20250404_132509_Gallery.jpg as do Associated spur gears. Horizon Hobby still makes the shock cartridge sets at $4.99 but you can rebuild the ones you have unless the hex or threads are trashed. DPRC.com makes other losi specific re makes, but the gold shock shafts are wayyyy to unfinished...like they forgot the polish phase. Shelf parts only as of now...too bad too. Boki racing makes a very very nice remake shell (I think the 8017 is the correct CR shell). Any stripped out plastics or trans case holes etc...replace the 4/40 screw with a 3mm screw (I would tap with 3mm first on a graphite part) and instant fix, this includes ball studs-
What else?
Nice! I didn't know that. Printing some up in PETG shortly....RogueIV wrote: ↑Sat Apr 26, 2025 2:30 amI'm just saying, I made the wheel adapters first. If you have a 3d printer then you can make them for free. https://cults3d.com/en/3d-model/game/12mm-jconcepts-mono-wheel-bearing-adapter-for-older-losi-trucksCharlie don't surf wrote: ↑Thu Apr 24, 2025 5:40 am What are you planning on doing with it? XXt CR Graphite plus is a very capable vintage race platform. Transmission cases are weak spots, Jeff at Factoryworks.com makes a very cheap.trans brace tab that helps safeguard the cases (unless the T plate breaks too....and they can.... then both are trashed)
What else?
- Has thanked: 665 times
- Been thanked: 473 times
Where can you get these from new?Charlie don't surf wrote: ↑Thu Apr 24, 2025 5:40 am Horizon Hobby still makes the shock cartridge sets at $4.99 but you can rebuild the ones you have unless the hex or threads are trashed.
Horizon Hobby!Retro rc wrote: ↑Sun May 11, 2025 9:45 pmWhere can you get these from new?Charlie don't surf wrote: ↑Thu Apr 24, 2025 5:40 am Horizon Hobby still makes the shock cartridge sets at $4.99 but you can rebuild the ones you have unless the hex or threads are trashed.
Holy crap thanks for that CharlieCharlie don't surf wrote: ↑Sun May 11, 2025 9:58 pmHorizon Hobby!Screenshot_20250511_215621_Chrome.jpgRetro rc wrote: ↑Sun May 11, 2025 9:45 pmWhere can you get these from new?Charlie don't surf wrote: ↑Thu Apr 24, 2025 5:40 am Horizon Hobby still makes the shock cartridge sets at $4.99 but you can rebuild the ones you have unless the hex or threads are trashed.
- RogueIV
Wait, WHAT?!Charlie don't surf wrote: ↑Sun May 11, 2025 9:58 pmHorizon Hobby!Screenshot_20250511_215621_Chrome.jpgRetro rc wrote: ↑Sun May 11, 2025 9:45 pmWhere can you get these from new?Charlie don't surf wrote: ↑Thu Apr 24, 2025 5:40 am Horizon Hobby still makes the shock cartridge sets at $4.99 but you can rebuild the ones you have unless the hex or threads are trashed.
- 54 Replies
- 11437 Views
Last post by mikesofunny
- 2691 Views
Last post by MAC10
- 1346 Views
Last post by Potter
- 2211 Views
Last post by Diamond Dave
- 2082 Views
Last post by urpaldan
- 2280 Views
Last post by FasterLouder
- 26 Replies
- 4383 Views
Last post by bird
- 90 Replies
- 20454 Views
Last post by Lavigna
Users browsing this forum: Google [Bot] and 3 guests
