RC10 long travel (RPM Style) new build
LusBus
Been thanked: 46 times
Post by LusBus »
New build: RC10 RPM Style long travel with truck nose plate. I found some parts which haven't been used for a long time in my collection, they fitted together quit well, had to add a few things and this is the result. I will finish it this weekend, has smooth long travel, very promising, hope it will handle well on my "vintage style" bumpy backyard track.
picture url
RC10 collection in Switzerland: Original, Classic (ReRe), "Plastic" (homemade milled white cahssis), CE, Graphite-Andys, TeamCar, WorldsCar, WorldsCar ReRe, "CouldHaveBeen" (homemade similar to "RPM"), B3, 3x B4, 2x B5
Dustydrone
Has thanked: 532 times
Been thanked: 110 times
Re: RC10 long travel (RPM Style) new build
Post by Dustydrone »
Great build, looks like an awesome backyard ripper 👍
LusBus
Post by LusBus »
If anybody is interested, you can ask for the files for the A-arms. After I had more or less all parts I designed the arms to give it 246 mm of width using "modern" wheels.
They are longer than old RPM because the "modern" wheels have not the same offset as vintage ones.
Parts used:
Chassis, noseplate, front bulkhead: RC10T
Transmission: Thunder Tiger, fitted with adaptor parts, CAD-designed an printed from black ASA
Rear hub carriers: Thunder Tiger
Rear CVD and wheel axle: B4
Front C-hub and hub carrier: RC10 design with added pad for set screws (no E-clips needed), printed from polyamide (Neat NT)
Shock towers: homemade, milled from 2mm carbon, rear original outline, front with added holes to fit buggy needs
Shocks: Don't remember maybe some RC10 T4
Hinge Pins: Made from 3,2mm steel bar stock
A-arms: designed in CAD an printed from natural polyamide (Filamentum Nylon FX256), if they break I will mill the next ones.
Designed a clamp to fit the mini-drill into the old lathe to cut grooves for E-rings in steel rods:
