Tamiya Novafox/Factory Works No Fox Given
The place for all things re-release Tamiya.
mtbkym01
Has thanked: 190 times
Been thanked: 274 times
Post by mtbkym01 »
Building one of these up for some Vintage racing, because I didn’t just want to be like everyone else.
Starting out with a New Kit
With some JC Racing original style 2.2 wheels, and Schumacher Astro Tyres. Also using RC10 wing wire and buttons, and Schumacher Top Cat wing
HW Quicrun and Fantom 21.5T brushless - this is spec for where this will be raced
Then the good stuff arrived
If it's Old Skool, It's Kool
mtbkym01
Re: Tamiya Novafox/Factory Works No Fox Given
Post by mtbkym01 »
Started assembly
And I’m into the Novafox kit almost immediately
My kit was missing the bits for the front body mount (Which I’m not bothered by). I sorted out a work around with other parts
The standard sway bar will get tried, as in the instructions it states it works quite well with the Factory Works kit
Then it’s onto the rear end
More to follow in the next day or so
Has thanked: 1735 times
Been thanked: 1145 times
Looks great so far, @mtbkym01 .... will we be seeing this at the Bash later in the year? If so, will be good to catch up with you (and this!) finally :)
coxbros1
Has thanked: 2758 times
Been thanked: 2407 times
Post by coxbros1 »
Cool mother fxxking build!....glad u went with the white fiberglass too..looks classic....definately be following this build..be sure to enter it in botm..need more Tamiya entries..eventually one has to win
coxbros1 wrote: Wed Mar 19, 2025 5:13 pm ..need more Tamiya entries..eventually one has to win
Tamiya and winning not usually in the same ballpark :P :P :P
mtbkym01
Post by mtbkym01 »
@Incredible_Serious Not sure I’ll get to the bash, but I’m building this for Vintage Demo at Nats in Adelaide in November. I will get to the bash at some point though, I have massive FOMO seeing the pics.
@coxbros1 depending how it turns out, I will enter it for sure. I did actually win a BOTM with a Tamiya once, an early Rough Rider resto I did. And agree the natural looks better than the black IMO, gives a more vintage feel i reckon.
mtbkym01
Post by mtbkym01 »
Grabbed an hour or so after work in the hobby room to do a bit more. I’m doing my best to avoid the standard kit screw pins in this build so its good to have these on hand
And fitted, they look great IMO
Thats almost the front end done, the Factory Works kit comes with threaded rod for the steering linkages, but I’ve decided titanium turnbuckles will suit this better, so quickly placed an order through my local “preferred” seller.
I then thought I’d make a start on the gearcase, and for this I wanted to slow the open diff down so used this Losi Super Tacky Diff grease. Feels like it has slowed the action nicely
Unfortunately, the rear lower screw pins for the lower suspension arms, are longer than the 2 long ones I have remaining from the TL01 kit above. Well not exactly, they are the same as the lower front, but the pins don't pass all the way through, so I need to get some longer ones. Tamiya do a set for the M05 V2 that appear to have a couple longer ones, so I’ve ordered some from Plaza Japan, along with some other items from my wish list to beef up the order.
So will be waiting now for parts to arrive from Japan before I can progress any more, but so far so good
mtbkym01
Post by mtbkym01 »
Worked around some areas while waiting for parts
Hoping to use a shorty lipo, but will depend if the body fouls with bullet plugs.
I also have a dilemma with shocks. The kit CVA’s can actually function quite well, but yellow wont work with the scheme i have planned for this, so I could dye them black, or attempt to locate some shocks from something else that may work
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
Looking great so far.... Did you use washers/spacers for the hinge pins, if so it's a very tidy way to use pins slightly too long.
You can never go wrong with AE shocks :lol:
mtbkym01
Post by mtbkym01 »
Yep I did RJ, just some nice alloy spacers. Big Bores are kinda frowned upon, so is there a particular AE shock I should look for?
mtbkym01
Post by mtbkym01 »
Trimmed the body to test fit, happy so far
8rad
Has thanked: 9 times
Been thanked: 38 times
Post by 8rad »
WOW... :shock: Never had a fox. Always wanted one.
76jimmy
Has thanked: 23 times
Been thanked: 16 times
Post by 76jimmy »
I built a Nova fox in 2020. Just a clean box art buggy. I think I ran a few packs on it and it's been hanging up in the collection. Makes me want to get it out again.
LurkingCAT
Has thanked: 202 times
Been thanked: 271 times
Post by LurkingCAT »
I had a Fox in the mid eighties (mkI) and rebuilt it soon with the Hot Trick conversion.
Still have a few Foxes but never done this one - Very cool build!
I'm driving both the original gear diff and the Thorp ball diff.
Interesting with the diff grease, and will be good the hear an evaluation. Will it stick to the diff or contaminate the drive line causing drag?
Assembled and shimmed correctly the gear box is very free, making the Fox extremely light footed :D
mtbkym01
Post by mtbkym01 »
LurkingCAT wrote: Mon Mar 24, 2025 7:44 am I had a Fox in the mid eighties (mkI) and rebuilt it soon with the Hot Trick conversion.
I think the diff grease should stay in place as it’s only on the diff. The diff action shouldn’t spin enough to move it, and the rotation of the main gear shouldn’t cause it to fling either i don't think.
Return to “Tamiya Re-Release Forum”
