** 2025 RC10Talk.com Roostpalooza - April 12-13 - Insanity Race Track - Boonton, NJ **
Post about upcoming or past events.
Dig out your big pins and ribs and come join us for vintage race on a loose dirt track. A lot of people have been asking for a race on this kind of surface, and we were in a position to make it happen before the normal hard packed layout goes in for the season.
Rules:
2wd - 1997 cutoff (RC10B3, Losi XX or older). Rear motor only. 17.5 blinky.
Stadium truck - 1997 cutoff (RC10T3, Losi XX-T and older). Rear motor only. 17.5 blinky.
4wd - Any Vonats legal 4wd buggy from both 4wd and classic 4wd classes (Losi XX-4, Kyosho Optima, etc.). 13.5 blinky.
2wd Y2K - Any rear motor buggy from 2000-present (RC10B4, RB10, Losi XXX,..). 17.5 blinky.
** AMBrc, MRT, or Mylaps 2 wire transponders ONLY. Mylaps 3 wire transponders WILL NOT WORK. **
** BRING CASH TO COVER ENTRY FEES **
carloco8
Has thanked: 74 times
Been thanked: 271 times
Re: ** 2025 RC10Talk.com Roostpalooza - April 12-13 - Insanity Race Track - Boonton, NJ **
Post by carloco8 »
That is really awesome that they are going to change up the track surface for the event! 8)
stickboy007
Been thanked: 55 times
Post by stickboy007 »
It's not being changed for this event specifically. It's more like we get to run on the surface before it gets packed down for the season. Either way, we get a loose dirt race and it should be good fun.
RogueIV
Has thanked: 2135 times
Been thanked: 1099 times
Post by RogueIV »
Booked my Hotel a few days ago. Now need to figure out tires.
So what's everyone's goto for actual dirt tires for buggies and trucks?
Jconcepts is coming out with a 2.2 Step Pin style buggy and truck tire in dirt compounds. Hopefully available before the race. I plan on running those with ribs up front.
It's hard to know what will work. But we'll have a better Idea for next year. :lol:
stickboy007
scr8p wrote: Thu Feb 27, 2025 9:17 pm Jconcepts is coming out with a 2.2 Step Pin style buggy and truck tire in dirt compounds. Hopefully available before the race. I plan on running those with ribs up front.
I'm not holding my breath for those tires. Goosebumps have a quite similar tread depth and style anyway...
RogueIV
Post by RogueIV »
will probably end up using kyosho tires after I found I can stretch them onto my 2.2 wheels. I'll probably do a little testing at my lhs's 1/8scale track that hasn't been touched over the winter for traction testing. Not an apples to apples test but it'll at least give me some kinda feedback.
stickboy007 wrote: Tue Mar 04, 2025 9:51 pm
You can still kinda find them, but Goosebumps are discontinued.
stickboy007
scr8p wrote: Wed Mar 05, 2025 10:24 am
Bah. Go figure. I have a few sets with low or zero use, so thankfully I'm all set. I may buy some step pins if they come out in time anyway, because who knows for how long they'll be available.
Mark Westerfield
Has thanked: 14 times
Been thanked: 39 times
Post by Mark Westerfield »
I'm planning on mounting JConcepts Drop Steps front and rear for our team's tires in Y2K buggy.
stickboy007
Mark Westerfield wrote: Wed Mar 05, 2025 12:40 pm I'm planning on mounting JConcepts Drop Steps front and rear for our team's tires in Y2K buggy.
Pink is a soft-ish turf compound. Maybe if it's warm enough, that will be okay...?
RogueIV
Post by RogueIV »
Another thing I'm thinking about, do I attempt to ironman all 4 classes? how stacked are the heats going to be? What's the Pit and Power situation?
stickboy007 wrote: Wed Mar 05, 2025 1:35 pm
going to be honest I have a pair of drop steps and they feel pretty firm. might still work though. It'll almost be like running period tires before we had super soft compounds and foam inserts. I also have some Schumacher CAT tyres that may work, really chunky blocks, but it's in yellow compound so a bit firm. I have a feeling I'll be bringing a lot of random tires with me to test lol.
RogueIV
Post by RogueIV »
Mounted some tires to my test vehicle. Not sure if I'll actually use this NIX91 at the race but its a good platform to test tires on.
Mark Westerfield
I'm not sure why you guys want a soft compound tire for a loose packed, loam surface. Soft tires are to conform around small irregularities of a smoother, harder surface to get grip. On a loose packed, loam surface the pins need to penetrate and push against the dirt.
On an extreme end, think about how useless having a super soft compound would be with paddle tires in sand - the paddles would fold over and you would have less acceleration.
stickboy007
Mark Westerfield wrote: Thu Mar 06, 2025 5:43 am I'm not sure why you guys want a soft compound tire for a loose packed, loam surface. Soft tires are to conform around small irregularities of a smoother, harder surface to get grip. On a loose packed, loam surface the pins need to penetrate and push against the dirt.
It all depends on temperature, loam depth, etc. A hard pin is not uniformly the answer to a loamy surface.
Return to “Racing News / Get-Togethers”
