Tamiya Top Force - Kit No. 100
mtbkym01
Has thanked: 190 times
Been thanked: 274 times
Post by mtbkym01 »
I’ve had this original for a number of years, so finally made a start on stripping it down for a complete clean and rebuild. Will have to replace the rear gear case as it is broken where the shock tower attaches, other than that, all original parts will be used. I am going to replace the camber links with titanium turnbuckles, and am using stainless hex hardware in place of the original self tapping screws.
This ESC fitted, period correct, although I’ve never seen one before
Going with Yokomo MX4 hubs and wheels, as these are in great condition, but aren’t being used on my MX4 build. Trinity tyres
If it's Old Skool, It's Kool
mtbkym01
Re: Tamiya Top Force - Kit No. 100
Post by mtbkym01 »
Using the original manual, started with rebuilding the diffs
Going with a Super Stock TZ in this build, the blue anodized colour will match my theme
Titanium turnbuckles
So here’s the rear clip rebuilt
And the front
Both together
Next will be shocks, this one is getting an upgrade from the kit CVA’s. These have become really rare and very expensive now, but I bought them for this kit back when they were re-released, so will open them up for this
mtbkym01
Post by mtbkym01 »
Already completed a TBG body with MCI stickers. I painstakingly cut out all of the kit green from the sticker set, as it would’ve looked odd with the colours I’m using
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
Looking good, can't wait to see the finished car
mtbkym01
Post by mtbkym01 »
RC10th wrote: Sat Feb 01, 2025 2:58 am Looking good, can't wait to see the finished car
Thanks RJ, hopefully this one doesn’t take as long as my others LOL.
coxbros1
Has thanked: 2758 times
Been thanked: 2407 times
Post by coxbros1 »
Nice rebuild!
mark
Has thanked: 14 times
Been thanked: 90 times
Post by mark »
Nice work on the body
mtbkym01
Post by mtbkym01 »
Very hot day here today, making my workshop quite warm, so managed a little bit more on the rebuild
First up were the HiCap shocks
Then the chassis finally makes an appearance, the alloy posts needed a bit of a polish, a couple were held with pliers on the original build, which scored them quite deeply, I can see why they were clamped so hard, because self tapping screws were used instead of machine thread screws on original assembly :shock:
Using the standard steering bellcranks, but replaced the metal bushes with rubber sealed bearings, and more titanium turnbuckles
Then it was time for the front and rear assembles to be fitted to the chassis, so took the opportunity to sit it on its wheels
Next up is electronics…..
mtbkym01
Post by mtbkym01 »
Electronics and top deck installation completed, using all the original electronics including the AM rx. We are so spoilt these days with 2.4 stuff. The antenna wire on this is so long, I’ve forgotten how best to ‘arrange’ it
I’ve had to order a J parts tree as I’ve found some broken bits, but took the opportunity to see how the body looks
mtbkym01
Post by mtbkym01 »
Got antenna wire tidied, undertray fitted (left it clear), and wing mount all cleaned and polished
From here, it’s basically finished, just waiting on battery straps to arrive, had to get it done for BOTM otherwise I would’ve waited for the straps. Got a Tamiya period correct stick pack in there as well.
I’m really happy how this turned out. The Top Force is a unique looking buggy, some angles it looks so sleek, others make it look a bit fat. But being kit number 100 from Tamiya, it has a bit of an iconic presence in my opinion.
Thanks for looking
Return to “Tamiya Forum”
