Steering ball cups popping off 40th
Sedizzle
Been thanked: 11 times
Post by Sedizzle »
Pretty sure this is a common problem and after coming up empty from a search thought I would ask here.
Is there a readily available upgrade or solution for the steering ball cups popping off? When I tap the drain pipe its about a 50/50 if one pops off my 40th.
Thanks!
clutchcargo
Has thanked: 145 times
Been thanked: 20 times
Re: Steering ball cups popping off 40th
Post by clutchcargo »
Sedizzle wrote: Mon Jan 13, 2025 8:50 pm Pretty sure this is a common problem and after coming up empty from a search thought I would ask here.
Thanks!
Hey Buddy mine is still in box, but I have heard of them not being too good. Maybe try RPM a certain are around steering might rub from what I heard. You can trim.it to clear. Not really sure what else might be out there?? RPM has long and short shank, I always forget which to buy? THIS up there site and look, even send a email to make sure. Hope this helps a bit, some guys here are really incredibly smart and ALL are helpful.
JosephS
Has thanked: 1209 times
Been thanked: 610 times
Post by JosephS »
Thanks!
I recall captured ball joints being used to solve this.
Has thanked: 265 times
Been thanked: 2032 times
RPM ball cups are really too bulky for a RC10 buggy, particularly around the bellcranks and front shock tower area.
If you are set on white, the Fan RC cups might be an option. I think Hot Racing has some as well but I don't know the quality.
If color doesn't matter, Schumacher short ball cups are excellent.
LurkingCAT
Has thanked: 193 times
Been thanked: 270 times
Post by LurkingCAT »
If you opt for captured ball joints, make sure you also get the cone spacers depicted by JosephS.
Along with juicedcoupe I also have very good experience with Schumacher ball cups - I use them on several platforms.
Here are some grey Schumacher ball cups on a Hotshot. They replaced the ae ones I used previously.
LurkingCAT
Here is another setup with captured ball joints where cone spacers are used on the ones with vertical articulation.
The bell crank link joints are only fitted on a small washer.
1911Colt
Has thanked: 1708 times
Been thanked: 809 times
Post by 1911Colt »
Not vintage, but very effective. I have these on a couple of re-re Cougars.
Sedizzle
Post by Sedizzle »
Super helpful thank you all!
Users browsing this forum: No User AvatarAhrefs [Bot] and 5 guests
