Receiver switch
- Has thanked: 35 times
Receiver switch
Just got a Futaba 3PV 3-Channel Radio with R304SB T-FHSS Receiver . Lot of receiver switches out there I've had some bad but a couple decent. No wrong answer and I'm open to reasoning. What's a durable/reliable switch?
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
Re: Receiver switch
I've never had a receiver with a switch.
If using an esc, the switch on the esc controls all power (via it's bec).
If using a separate receiver power pack or external bec, an inline switch can be used.
Re: Receiver switch
Ok, I've 0nly had old electronics and this is the first time I've gone newer than early 90s. Always had a small independent switch of some sort to turn it on. I've seen a few new ones for salejuicedcoupe wrote: ↑Fri Dec 13, 2024 4:37 pm I've never had a receiver with a switch.
- juicedcoupe
Re: Receiver switch
What are you planning on doing? That will determine if you need an external switch or not.Liveaxle wrote: ↑Fri Dec 13, 2024 8:24 pmOk, I've 0nly had old electronics and this is the first time I've gone newer than early 90s. Always had a small independent switch of some sort to turn it on. I've seen a few new ones for salejuicedcoupe wrote: ↑Fri Dec 13, 2024 4:37 pm I've never had a receiver with a switch.
Re: Receiver switch
Just installing esc/receiver/ battery to functioning state.juicedcoupe wrote: ↑Fri Dec 13, 2024 8:39 pmWhat are you planning on doing? That will determine if you need an external switch or not.Liveaxle wrote: ↑Fri Dec 13, 2024 8:24 pmOk, I've 0nly had old electronics and this is the first time I've gone newer than early 90s. Always had a small independent switch of some sort to turn it on. I've seen a few new ones for salejuicedcoupe wrote: ↑Fri Dec 13, 2024 4:37 pm I've never had a receiver with a switch.
- juicedcoupe
Re: Receiver switch
Then there is no need for an extra switch.
The power for the receiver and servo will be supplied through the esc's plug.
When the esc is switched on or off, it will control power to the whole system.
Re: Receiver switch
10 4. What would necessitate a switch? Why did the old ones have one?juicedcoupe wrote: ↑Sat Dec 14, 2024 5:46 pmThen there is no need for an extra switch.
- juicedcoupe
Re: Receiver switch
Old setups with mechanical speed controls required another method of supplying power to the receiver and servos.
Some cars used a separate battery pack to supply power, routing it through a switch.
Others routed power from the main battery pack to the receiver, also through a switch. These required the receiver to have an internal bec when using 6-7 cell batteries.
If you are referring to old esc's, I have never had one without a bec. Although, it is likely that early models didn't have them.
Oddly enough, I've got two Aristocrat esc's with broken bec's. If I ever use them, I'll have to rig something up.
- juicedcoupe
Re: Receiver switch
Delete, double post.
- 805 Views
Last post by Halgar
- 237 Views
Last post by Dangeruss
- 881 Views
Last post by juicedcoupe
- 624 Views
Last post by JosephS
- 892 Views
Last post by treehugger
- 989 Views
Last post by integra22t
- 1994 Views
Last post by Lizardking
- 518 Views
