Team Losi Big 6 in '96
Dangeruss
Has thanked: 432 times
Been thanked: 1421 times
Post by Dangeruss »
Team Losi advertising their competitive wins for the year, as well as the new XX CR, XXT CR and upcoming XX4:
XX CR - Released in 1996 as an updated version of the XX 1/10 electric off-road buggy. 3-piece molded composite plastic "G-Tunnel" chassis with raised side pods, hinged front bulkhead, chassis reinforcing upper brace, plastic battery strap and 3-degree bolt-in rear pivot plate/support block. New a-arms with provisions for a sway bar mount, 25-degree camber blocks and bearing integrated spindles, turnbuckle/bellcrank steering, built in servo saver, Ackerman adjustable drag link. Composite rear shock tower, fiberglass plate front shock tower and Hard Body, teflon coated, oil-filled aluminum coilovers with softer springs all around. Rear h-arms with additional shock mounting hole and 0-degree rear hub carrier. Laydown, ball diff, 2.19, 3-gear, Hydra-Drive equipped transmission with steel universal style axles. New 5-spoke wheels with Silver Compound IFMAR Pin rear tires and Gold Compound Wide Body front tires. Full bearings, new lower profile clear lexan body with V-Wing. Sold unassembled, less radio and electronics.
XXT CR - Released in 1996 as an updated version of the XXT 1/10 electric stadium truck. .30 inch longer 3-piece molded composite plastic "G-Tunnel" chassis with raised side pods, hinged front bulkhead, chassis reinforcing upper brace, plastic battery strap and wider 3-degree bolt-in rear pivot plate/support block. New a-arms with provisions for a sway bar mount, 25-degree camber blocks and spindles, revised turnbuckle/bellcrank steering with built in servo saver and Ackerman adjustable drag link. Standard composite front shock tower, lower mounted composite rear shock tower, and Hard Body, teflon coated, oil-filled aluminum coilovers all around. Shorter rear h-arms with wide set shock mounting hole and 0-degree rear hub carrier. Laydown, ball diff, 2.61, 3-gear, Hydra-Drive equipped transmission with steel universal style axles. Truck spec 2.2 Disk Wheels with Silver Compound IFMAR Pin rear tires and Silver Compound Directional Rib front tires. Full bearings, new longer and lower profile clear lexan body. Sold unassembled, less radio and electronics.
XX-4 - Released in 1997 as a 1/10 4wd off-road buggy. Smooth mini-tub graphite composite plastic chassis with molded in saddle pack battery indentions, cam adjustable motor mountd on the leading edge of the tub, double pad slipper clutch, triple belt drive system with front and rear mounted ball differentials and steel universal axles at all four corners. "Clicker" spring-loaded ratcheting gear attached to the front drive cog adjusted off-power free-wheel in the front drivetrain which could be locked in for full engagement. Akerman adjustable steering, 4-wheel independent lower a-arm/adjustable camber link suspension, composite shock towers, Teflon coated oil-filled Hard Body coilover shocks with adjustable collars. Molded 5 spoke hex mount 2.2 wheels, Losi Silver IFMAR Pin tires, and Teflon sealed bearings. Sold as an unassembled kit with tight fitting clear lexan body, less radio and electronics.
Team Losi 2-page ad combined into a single page poster:
