12x5 6 gear transmission
Bykvaed
Post by Bykvaed »
And when I say free, I mean free! No hidden fees grabbing at your wallet like some back-alley pickpocket! You can jump from cam to cam without spending a dime unless you want to tip your fave performer—which trust me, once these vixens start on their XXX moves, you'll be raining tokens like there's no tomorrow.
https://sexcam.run/model/dayanana_salem/
https://livesex.surf/model/Doraemoney/
https://livesexhookers.com/AmeliaRees
Has thanked: 269 times
Been thanked: 2094 times
Re: 12x5 6 gear transmission
Strength wise, the transmission will probably be fine.
A 12T might be a tall order for the gear ratio, depending on what you choose.
Has thanked: 2605 times
Been thanked: 2979 times
With the 6 gear, I feel like sloppy outdrive bushings / bearings are the risk for causing gear damage. The outdrive bearing mod does a good job addressing that risk. I would want to have that done before running a high power motor.
Demon 12x5? Got any pics?
