40th Undertray
Sedizzle
Been thanked: 11 times
40th Undertray
Post by Sedizzle »
Anyone know if the the TBG undertray will fit the 40th? I saw another vendor selling an undertray claiming theirs has fitment issues with the 40th. TIA
RogueIV
Has thanked: 2135 times
Been thanked: 1100 times
Re: 40th Undertray
Post by RogueIV »
I don't know, but If it has issues fitting the 40th then it has issues fitting any of them.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Re: 40th Undertray
Post by RC10th »
You should consider a chassis protector with your undertray depending on where you run, from my experience the underdray traps dirt in and under it and basically sands your chassis.
Sedizzle
Re: 40th Undertray
Post by Sedizzle »
RC10th wrote: Sun Jul 21, 2024 1:07 am You should consider a chassis protector with your undertray depending on where you run, from my experience the underdray traps dirt in and under it and basically sands your chassis.
Awesome, thank you for the recommendation.
Sedizzle
Re: 40th Undertray
Post by Sedizzle »
RogueIV wrote: Sat Jul 20, 2024 5:32 pm I don't know, but If it has issues fitting the 40th then it has issues fitting any of them.
Thanks for confirming it seemed strange but wanted to check with the experts.
drc35ca
Re: 40th Undertray
Post by drc35ca »
I would use a undertray,as far a sanding a chassis clean it out after a run,make a few solid jumps with any rc10 buggy on hard rock,pave and cement without a undertray and see which one is sanded and gouged out ?? I bought a few off of ebay and it protects the chassis from nose to up under the motor to the screws the hold the motor mount to the chassis.
