Here comes the 60th anniversary EXT gold version. I have it sitting under my desk for a few months waiting a day where I do not have motivation to do CAD, and where the weather outside is crap. That was today.
This car will be a runner (and I don't mind running a 60th anniversary version : for me those cars are built to run)...
The ESC will be a Kyosho Le Mans (and although beside the color it is the same as a Performa P1 ESC, the performa programmation card doesn't work with it). The motor will bea 21.5T brushless. I did not decided yet for the battery, but it will be likely a shorty Lipo pack ...
When you open the box, it is quite a call to build it : no blister, just bags...
And there is a change in the instructions for the ball dif compared to the manual...
The first step is like the Fantom EP4WD : you assemble the front carriers... One key thing to note is again the right side as an inverted thread compared to the left side (so be careful to the groove and markers for the right side)
Then we lay out all the parts to assemble the center piece of the front train, including the one way that allows to deal with the smaller wheels on the front side...
The assembly is pretty simple... But as there is gaps between the knucles you are advised to glue the bushings on the sides (something you don't need to do on a Fantom non EXT).
Then we place the knuckles on the ends, with a spring which acts as a suspension... Hint: start with the top and the spring.
Next is tie rods and steering servo... The servo saver is mounted directly on the servo, which is different than for the first version...
The sevro is mounted on a chassis, and it can be adjusted so it is in plan center.
Next come the ball differential...
The next part is the motor mount and the rear axle holder...
The ESC is fixed to the bottom plate and sandwiched with the upper plate... At this stage, I did not made any of the motor wiring as I need to decide about the battery...
I then assembled the shock and it is fixed at the rear and not snaped at the front at this stage. I'll do this once the electronics are fully set in place...
I trimmed the bodyshell and I'm yet to decide for the battery... This car needs to be operational the latest early september, but I may have an occasion to run it sometime in July, which means I may want to finish earlier...
