Fan RC FR-01
jonboy
Has thanked: 10 times
Been thanked: 14 times
Fan RC FR-01
Post by jonboy »
Hi Guys, I'm surprised there is no stuff on youtube or here .. anybody got one yet? I'm considering it as a runner.
Cheers
Jon
morrisey0
Has thanked: 87 times
Been thanked: 1852 times
Re: Fan RC FR-01
Post by morrisey0 »
As far as I know, none have gone out. I ordered one, but not sure if I am in the first group or not.
Has thanked: 2604 times
Been thanked: 2977 times
Re: Fan RC FR-01
There was some discussion.
https://www.rc10talk.com/viewtopic.php?p=567490&hilit=fanrc#p567490
It looks like its preorder only right now. It looks interesting.
Been thanked: 3917 times
Re: Fan RC FR-01
A couple people on facebook have them, including the owner of Klinik
2BornotB2
Has thanked: 9 times
Re: Fan RC FR-01
Post by 2BornotB2 »
I'm building one up, but following the Worlds re-re instructions and also Mark Westerfield's build, which calls for "3x .125" downstop spacers. As FanRC's kit doesn't include these spacers (only includes the 0.031" size), and ASC6466 is out of production, what recommendations?
I'm thinking my daughter's Perler beads, but they're a hair over 5mm in height each.. 3x 0.125" is about 9.5mm so I'd be about 0.5mm too much. Time to start trimming...
Editing to add Mark's build thread:
https://www.rc10talk.com/viewtopic.php?t=6600
Re: Fan RC FR-01
The difference in setups is going to be dependant on the shock shaft. FanRC shocks are 1.32 shafts which will require the spacers but the worlds rere came with 1.02 shafts and thus used much thinner spacers. I would have to assume with Marks setup he is using 1.32 shafts since that is a lot of spacer. Original spacers were fuel tubing cut to 5/8"- far more than the 3/8" mark is using. If you are within a .5mm of where mark sets his up you will be just fine. For a racer, personally I'd buy a pair of 1.02 shock shafts and run it like the world's cars
2BornotB2
Re: Fan RC FR-01
Post by 2BornotB2 »
Cool, thanks - I wasn't aware of the shock lengths. I have the Classic re-release from 2013ish but I missed out on the Worlds car.
I plan to run it on a tight(ish) indoor carpet track so getting the car lower would help corner handling.
Re: Fan RC FR-01
3 1/8 spacers on Mark's car is probably correct with 1.32 shafts using the outer arm hole. 5/8 is for when you use the 2nd from outside arm hole.
RogueIV
Has thanked: 2133 times
Been thanked: 1098 times
Re: Fan RC FR-01
Post by RogueIV »
Anyone have any issues with their transmission in these? mine seems to bind up quite a bit
Has thanked: 268 times
Been thanked: 2094 times
Re: Fan RC FR-01
RogueIV wrote: Fri Aug 02, 2024 11:07 pm Anyone have any issues with their transmission in these? mine seems to bind up quite a bit
Sounds like an exact copy of the re-re Words transmission, problems and all.
The fix for them was an early style case and idle gear. Luckily, Associated is supposed to have some later this month.
Re: Fan RC FR-01
It'll be fine after you run a pack or 2 through it.
Rc10812
Has thanked: 35 times
Been thanked: 11 times
Re: Fan RC FR-01
Post by Rc10812 »
I just started building my kit. Gonna be a long build because I don't get a lot of time to spend on it right now. I literally got hung up on step 2. The steering bellcrank did not turn out as good as I hoped. The plastic bushings don't offer enough bite into the screws to inspire confidence in their ability to hold over time. And also they rub on the chassis as they turn. Probably just need a spacer... there are 4 nylon spacer looking things in "bag A" so I might try them and hope they aren't called for down the road in the assembly.
It's discouraging news to hear there's binding in the gearbox. Same for shock spacers that seem to be necessary but not included. I'm familiar enough with the rear shocks and the spacers they call for. I assume they are included? Anyone know? But it sounds like the front shock shaft is different than original... and it's longer so it does need spacers? Is that due to the size on the spring? I assume the spacer limits the amount of shaft outside the shock body? The difference between 1.02" and 1.32" being .3" so the spacer needs to be .3"?
Lol. Am I following this right guys? Haha
Rc10812
Re: Fan RC FR-01
Post by Rc10812 »
Sorry think I double posted...
Re: Fan RC FR-01
Rc10812 wrote: Sat Aug 03, 2024 8:11 pm The steering bellcrank did not turn out as good as I hoped. The plastic bushings don't offer enough bite into the screws to inspire confidence in their ability to hold over time. And also they rub on the chassis as they turn. Probably just need a spacer... there are 4 nylon spacer looking things in "bag A" so I might try them and hope they aren't called for down the road in the assembly.
With my graphite cars, I shortened the threads on the ball studs for the bellcranks.
Re: Fan RC FR-01
You just need to raise the bellcrank. You can't assemble it like you would on a tub chassis because the graphite chassis doesn't drop down like the nose plate.
