where did all the rib stadium truck tires go
- RC4X4
- Has thanked: 44 times
- Been thanked: 38 times
Looking for some 2.2 stadium truck rib tires today and nobody makes them anymore (or they are "out of stock"). Any suggestions for a set of fronts?
- Has thanked: 1129 times
- Been thanked: 3917 times
Re: where did all the rib stadium truck tires go
JC just dropped some today actually. He is UK but shipping isn't bad.
- morrisey0
- Has thanked: 87 times
- Been thanked: 1847 times
The Proline 4 Ribs are in stock in all the usual places. https://www.prolineracing.com/product/1-10-4-rib-m3-2wd-front-2.2-off-road-buggy-tires-2/PRO817502.html
- Has thanked: 36 times
- Been thanked: 1318 times
- carloco8
- Has thanked: 74 times
- Been thanked: 271 times
He posted in the truck forum, so maybe he meant front truck rib tires? Well, proline stopped making the edge tire for a good while now and yup, jconcepts carvers are out of stock everywhere. Depending on how loamy or loose your dirt conditions are, holeshots or double dees work well as fronts and if its not too dusty or loose, you could even get away with ellipses on a clean/swept/slightly dusty outdoor track.
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2092 times
- RC4X4
Yes sorry guys, could have communicated a little better.carloco8 wrote: ↑Wed Jun 05, 2024 10:12 pm He posted in the truck forum, so maybe he meant front truck rib tires? Well, proline stopped making the edge tire for a good while now and yup, jconcepts carvers are out of stock everywhere. Depending on how loamy or loose your dirt conditions are, holeshots or double dees work well as fronts and if its not too dusty or loose, you could even get away with ellipses on a clean/swept/slightly dusty outdoor track.
- juicedcoupe
Their tires are in and out of stock. I suspect that they do small batches. If you really want some, I'd message them in regards to the next batch.
- Dangeruss
- Has thanked: 425 times
- Been thanked: 1405 times
With the transition to indoor racing (clay/carpet) there's unfortunately a lot less demand for ribbed front tires. Jconcepts Carvers is the only racing tire currently being produced, with the JC Racing Products Double Ups as a possible alternative.
Don't know if they're out of production or just waiting on new batches but there's also Panther Tires:
Micro Rib:
And V Rib:
And in a pinch... HPI still makes their Front Line:
Micro Rib:
And V Rib:
- Regular Member
I followed the suggestion and tried HPI 4453 in the front (in combination with HPI 4410 in the rear) on my RC10GT and I am glad having tyres for clay (track was a bit softened due to moisture) but as the tyre compound is significantly harder than Jconcepts blue, while the inserts are quite soft I could continue enjoying the hobby but hoping to go back to my combination of Carvers in the front and Goose Bumps in the rear (which are a bit less impossible to get).
Thank you for posting the hint of alternatives (I can run again
) but I am really looking forward (and hoping) to grab some JC Carvers 3028 again.
- Been thanked: 37 times
I know this is a little bit late but..
Last year when I was doing my eGT build I picked up a set of these.
Amazon cheapies
They came with wheels but they're not glued. They've been real good for just general driving and having fun with. I'm not sure how well they'd do on a track but they certainly look the old 'vintage' part.
I might grab another set or two before they vanish.
Amazon cheapies
- Has thanked: 38 times
- Been thanked: 18 times
No clue how they perform but Jconcepts Swaggers have a somewhat ribbed design. Also happens to be one of the few styles they offer with wheels pre-mounted.
- 2053 Views
Last post by russ.shannon.3
- 1308 Views
Last post by LosiRacer1
- 1087 Views
Last post by YZ-10
- 1189 Views
Last post by Basher67
- 1994 Views
Last post by Mr. ED
- 1809 Views
Last post by R6cowboy
- 2775 Views
- 32 Replies
- 6436 Views
Last post by THEYTOOKMYTHUMB
