Firebrand Tires for buggies on street
HS-YZ250
Has thanked: 178 times
Been thanked: 155 times
Post by HS-YZ250 »
Has anyone used firebrand tires on their off road buggies to run on hard surfaces? They look to have a number of tread styles and a low offset that might work on older chassis.
Here is one example. Guessing they're the width of 4wd front wheels. They have a wider set that might match rears, if anyone remembers wheel widths off hand.
https://www.amainhobbies.com/firebrand-rc-neo-rt-2.2-premounted-onroad-tires-4-black-fbr1wheneo992/p824431
Losi LXT (JRX-T Conversion)
Losi JRX Pro SE
Kyosho Rocky
Parts-Car-to-Runner Kyosho Rocky
Yokomo YZ10 WCS '95 Pavidis
RJ Speed Spec10 "Chew Toy Mk1"
Redcat Lightning STK "Chew Toy Mk 2"
Kyosho Lazer ZX, ZX-R, ZX-RR
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Re: Firebrand Tires for buggies on street
Post by JosephS »
HS-YZ250 wrote: Wed Jun 05, 2024 2:57 pm Has anyone used firebrand tires on their off road buggies to run on hard surfaces? They look to have a number of tread styles and a low offset that might work on older chassis.
They are advertising these as for trucks. These may be larger than you'd want for a buggy.
Has thanked: 268 times
Been thanked: 2094 times
They list as 3.25" OD, which is normal for a buggy.
terry.sc
Has thanked: 7 times
Been thanked: 157 times
Post by terry.sc »
They are buggy tyres, sold over here as Fastrax Arrow. The link is a set of four, the fronts are only about 5mm narrower than the rears as they are 4wd wheels. The tyres are good for asphalt, but the wheels are a bit fragile though and have been known to break easily.
HS-YZ250
Post by HS-YZ250 »
I wish Horizon hadn't discontinued the Duratrax Banditos in buggy sizes. Was planning on putting them on future builds, but only my parts-to-runner Rocky will get to have them.
Losi JRX Pro SE
Kyosho Rocky
