I was looking into a stress reliever to have at work and I decided to make some surface plates by lapping. I was going to go for a 3 plate method by using iron, or mild steel, plates
What compound should I start with for lapping cast iron? Would valve lapping compound be the right place to start, or would I need a more abrasive compound? I'm hoping to have a rough starting figure on grit. I see everything from 80-1200. Is there a cheap but works compound?
Lapping Iron Plates
- Has thanked: 1243 times
- Been thanked: 639 times
Re: Lapping Iron Plates
Check McMaster carr for lapping compounds. The clover stuff is reasonably priced. The choices they offer gives you an idea of the surface finish you might be looking for.
- 28 Replies
- 1700 Views
Last post by badhoopty
- 2521 Views
Last post by Asso_man!
- 1634 Views
Last post by RC10th
- 966 Views
Last post by shodog
- 2020 Views
- 1856 Views
Last post by PBR Allstar
- 797 Views
Last post by drbelleville
- 570 Views
Last post by Chillout47
