Optima mid turbo - convert to Javelin
- Chillout47
- Been thanked: 4 times
I cant find a legendary series Javelin at the moment, is it possible to convert a Optima mid turbo using the roll cage? Is there anything else that I would need? Many thanks.
- mtbkym01
- Has thanked: 190 times
- Been thanked: 274 times
Re: Optima mid turbo - convert to Javelin
Not a Mid, need an Optima or Turbo Optima, then it can be done with a cage, roll bar, and possibly rear gearcase (Someone may be able to confirm) for the rear wing. Pargu also make wing mounts that attach to the cage
- Chillout47
Not mid, don't know why I typed that, thanks for confirming its rear motor Optima that I would need.
I like the gold on the Optima turbo so hopefully a conversion can be done. I'll download the manuals and compare gearbox casings and parts availability. I had not though about the wing mount.
- Chillout47
I checked the manuals, gearboxes look the same, wing mounts for Javelin are separate and bolt on the same as the spacers on the Turbo, and parts are available in UK. I see the Turbo has a skid plate, not sure if this can be used with the cage as well?. If there is something else I have missed please let me know.
- terry.sc
- Has thanked: 7 times
- Been thanked: 157 times
For the rereleases it's easy, depending on how accurate you want the conversion.
You need the OT247 cage set and OT252 wing in the colour of your choice, and the OT251 roll bar, OT250 wing mount. The driver figure is the same as the Turbo.
Obviously there are different shocks, wheels and tyres but the only difference between the two for the rest is the colour.
- 68 Replies
- 23187 Views
Last post by Garage Hack
- 52 Replies
- 13534 Views
Last post by HKS_TRD
- 3191 Views
Last post by Bo Wallen
- 19 Replies
- 9157 Views
Last post by lin6499
- 1822 Views
- 2201 Views
Last post by Lonestar
- 297 Replies
- 39076 Views
Last post by Wesleynm
- 2912 Views
Last post by RC10CE75
