The Infamous Idler
mAdMan
Has thanked: 134 times
Been thanked: 87 times
The Infamous Idler
Post by mAdMan »
These things still unicorn farts?
mikea96
Has thanked: 659 times
Been thanked: 878 times
Re: The Infamous Idler
Post by mikea96 »
There are quite a few on ebay at the moment
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Post by JosephS »
mAdMan wrote: Wed Dec 27, 2023 7:00 pm These things still unicorn farts?
Aluminum ones are easy to find.
mAdMan
Post by mAdMan »
JosephS wrote: Thu Dec 28, 2023 3:09 am
I don’t like the idea of passing the buck to the diff. I could put a metal diff in too, but I think that sends the weak link to the top shaft or the trans case itself right?
Has thanked: 269 times
Been thanked: 2094 times
Fan R/C is reproducing the re-re Words transmission, which uses a B4 idle gear. They should have them as well.
Been thanked: 3919 times
juicedcoupe wrote: Thu Dec 28, 2023 11:36 am Fan R/C is reproducing the re-re Words transmission, which uses a B4 idle gear. They should have them as well.
I dont think id be trying to use a 26t idler in place of a 28t idler, it would be pretty loose!
unless he really did modify the trans to use a 28t idler
GoMachV wrote: Thu Dec 28, 2023 1:16 pm
My bad. I thought that the re-re's actually used the then current B4 idle gear.
mAdMan
Post by mAdMan »
It’s a t4 trans so the b4 idler should work. I had one (9360) in my stash, and got it fixed. Just worried about killing this one and being SOL.
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
Check the tooth profile on the aluminum top shaft, if it's worn it will keep eating your idlers.
Users browsing this forum: No User AvatarElkcycles and 5 guests
