Kyosho tire experts?
- TRX-1-3
- Has thanked: 2068 times
- Been thanked: 992 times
OK the Micro Block series, W-5632 and W-5642..
I believe the W-5632 is a "narrow" front 4wd tire
I think the W-5642 is the wider rear tire.
Is this correct?
Did Kyosho make any Micro Block tires in a "traditional" 2wd front width?
I am researching for a build. Apparently the Kyosho micro blocks were the only tire that was hooking up at Aire Valley back in '92.
Is this correct?
- TokyoProf
- Has thanked: 563 times
- Been thanked: 418 times
Re: Kyosho tire experts?
I may not be able to answer your question exactly, but I got the following vintage Kyosho narrow block tires.
They say these tires are good for use on 4WD but also as rear tire for 2WD buggy---good for hard and dry surfaces. I wonder if that was true.
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2980 times
- TRX-1-3
Upon further....it appears AMR re-released the micro blocks back around 2020-2021. Only to be found over in Europe....hmm...shipping woes. I will retire to the nerdery and regroup. I do have a set of original Option House "narrow" 56mm's inbound from Hong Kong...
- TRX-1-3
OK, found a pair of W-5642 out of Germany. WMS. I used the guidelines in the scam/scam avoiding thread. The had their own email address. Well that's about all I checked. The seemed really legit otherwise.
https://www.wms-rc.com/de/
- Has thanked: 1129 times
- Been thanked: 3919 times
Wms is good, Ive ordered off them a few times. Just dont tell anyone about em
- TRX-1-3
Dang it! You never know when you're gonna "out" someone's super secret source. I've noticed some places dried up after I opened my big mouth in the past. Probably just coincidence....gotta watch out for the flippers though.
No I have already grabbed what I could from them. They have some good oddball stuff.
- TRX-1-3
Well, phooey. Ended up with a pair of W-5641 "H" pins. Order clearly reflects W-5642 "micro block". Not sure if I should launch an inquiry into the mix-up or just accept the "loss". I don't want to be a pest. The H-pins are a pretty neat tire, but I need the micro blocks for a "replica". Hmmmm.TRX-1-3 wrote: ↑Sun Dec 10, 2023 1:18 am OK, found a pair of W-5642 out of Germany. WMS. I used the guidelines in the scam/scam avoiding thread. The had their own email address. Well that's about all I checked. The seemed really legit otherwise.
- TRX-1-3
Well I decided to just ride it out. A pretty obscure set of old tires is cool enough and I'll just toss the 5641's in the "swappy/buildy options" box. But......Antony at KyoshoSpares out of the UK nailed it! He was kind enough to adjust his shipping radius and I have a set of 5642's heading my way!
Happy New Year!
Happy New Year!
- 2260 Views
Last post by Woobie
- 1526 Views
Last post by RedScampi
- 1877 Views
Last post by CWood
- 29 Replies
- 4435 Views
Last post by Mad Racer
- 1709 Views
Last post by oldskool
- 2588 Views
Last post by Hcp22
- 3613 Views
Last post by terry.sc
- 4395 Views
Last post by tamiyadan
