Best Liquid Mask product?
GreenBar0n
Has thanked: 1209 times
Been thanked: 786 times
Post by GreenBar0n »
I'm thinking of ordering and using Bittydesign liquid mask. Is there a better choice available today for RC bodies?
Done with tape bleed and poor curves:
Thanks!
BattleTrak
Has thanked: 1075 times
Been thanked: 584 times
Re: Best Liquid Mask product?
Post by BattleTrak »
I have only used the Bob Dively mask…it’s good stuff.
-Brad
mikea96
Has thanked: 596 times
Been thanked: 856 times
Post by mikea96 »
Bitty design works good but only with water based paints. Chemical based paint seem to react with it and it doesn't peel off then. Proline is also very easy to work with but I have only used it with water base paint as well.
GreenBar0n
BattleTrak wrote: Mon Nov 13, 2023 4:33 pm I have only used the Bob Dively mask…it’s good stuff.
Thanks! Looks like it's sold out everywhere, possibly out of production.
mikea96 wrote: Mon Nov 13, 2023 6:44 pm Bitty design works good but only with water based paints. Chemical based paontsbseem to react with it and it doesn't peel off then. Proline is also very easy to work with but I have only used it with water base paint as well.
Thanks for the reply. The video shows them using it for lexan bodies though:
Has thanked: 2407 times
Been thanked: 2698 times
GreenBar0n wrote: Mon Nov 13, 2023 7:51 pm
It is out of production. The factory literally burned down.
RogueIV
Has thanked: 1812 times
Been thanked: 843 times
Post by RogueIV »
absolutely not Spaz Stix unless you enjoy pain and suffering.
Also most airbrush paints for rc bodies are waterbased Acrylic. It's the spray cans you need to worry about.
GreenBar0n
Frankentruck wrote: Mon Nov 13, 2023 7:54 pm
Wow, that's why the abrupt disappearance.
RogueIV wrote: Mon Nov 13, 2023 8:12 pm absolutely not Spaz Stix unless you enjoy pain and suffering.
I'll be brushing this Bittydesign Liquid Mask on, unless there is an affordable airbrush kit worth recommending that I should purchase.
I'm using Tamiya poly carbonate spray paints, entirely throughout.
Any more guidance you can give me, I'd appreciate.
mikea96
Post by mikea96 »
The Proline stuff sprays on nicer and peels way easier than the bitty design.
GreenBar0n
What about this airbrush kit? Is there a better one in this price range?
www.amazon.com/Airbrush-Professional-Master-Multi-Purpose-Airbrushing/dp/B00EKT30JK
GreenBar0n
mikea96 wrote: Mon Nov 13, 2023 9:31 pm The Proline stuff sprays on nicer and peels way easier than the bitty design.
Just ordered the Pro-Line. Thanks! Do you use this with a brush or air brush?
mikea96
Post by mikea96 »
I spray it on with a mini hvlp touchup gun.
GreenBar0n
Something like this?
https://www.amazon.com/TCP-Global-Touch-Up-Spray-Regulator/dp/B00377535U
Would you say that's better for liquid mask/RC paint, than the airbrush kit above?
What compressor do you use?
Thanks!
BattleTrak
Wow, I didn’t know that.. guess I need to find a replacement when my bottles are finished.
-Brad
mikea96
Post by mikea96 »
I use this air compressor https://www.amainhobbies.com/paasche-d500-compressor-w-r75-regulator-pasd500sr/p35280
And I have been using this airbrush.
https://www.amainhobbies.com/iwata-hpbcs-eclipse-airbrush-iwaecl2001/p35360
And I just use a full size compressor for the mini hvlp.
GreenBar0n
mikea96 wrote: Tue Nov 14, 2023 8:03 am I use this air compressor https://www.amainhobbies.com/paasche-d500-compressor-w-r75-regulator-pasd500sr/p35280
Would you say in your experience that the airbrush, or the mini-HVLP gun, would be best for RC bodies? Thanks @mikea96 !
P.S. The Proline Liquid Mask is on the way here.
