help with parts
eddy
help with parts
Post by eddy »
hi all , i strip down the my rc10 to see what i need to get in parts , if some one can help me out that will be great .
thanks eddy :)
1,the short phillips flat head screw that holds the nose piece on .
2,the washers that go's under the body mounts.
3,front suspension mounts left/right hand #6207 .
4, "e" clips #6299 .
5,both metal ball ends - #6270 - #6271 .
6,front axle/front steering blocks white - #6219 - #6216 + all washers + nuts that comes with this deal .
7,front shock strut + hardwear #6230 .
8,all of the white plastic ball ends .
9,all of theservo saver parts white #6255 + hardwear.
10,all gear box bearings #6900 .
11,differential parts , thick thrustwasher with the small hole , blue thrust bearing , bearing adapors #6606 ,
teflon bushing small white #6623 , thick thrust washer with large hole , diff drive ring's #6625 ,
e-clips & washer to fit for #6610 spur gear white #6653 - balls #6626 , diff grease #6636 .
12,motor mount + screws #6607 .
13,felt/retainers #6633 .
14, rear arms #6355 .
15,spring/nylon washer's #6372 .
16, front wheel / rear wheel bearings kit .
17,front/rear shock kits with white parts + tool , oil , all hardwear mounting kit + front ,rear -
springs #6478 - #6497 .
18,nose brace tubes + screws #6320 - #6288 .
19,motor #6500 - pinion #6659 .
20,dust cover + hardwear #6608 .
21, all plastic servo mounts white + hardwear .
22,piano wire linkage + set collar # 6256 .
23,the speed controller reststor kit, the whole deal wire + plugs + hardwear .
24,battery trays kit white + hardwear #6334 .
25,front / rear tire's #6865 - #6815 ,nylon wing nuts #6390 .front / rear rims + hardwear .
26,wing mounting kit ,
27,any decal's to do with the car.
28, gold aluminum chassis #6300
justinspeed79
Post by justinspeed79 »
That's all? :shock:
Asso_man!
Has thanked: 40 times
Been thanked: 82 times
Post by Asso_man! »
well, you just need a complete buggy... if you like, I'll sell a complete original gold tub soon that is in pretty good shape :lol:
Come and visit the stable
Has thanked: 35 times
Been thanked: 1262 times
justinspeed79 wrote:That's all? :shock:
that's what i was thinking.
you'd be better off buying a nib rc10. there's also new built, never run rc10's that are on ebay quite often.
MelvinsArmy
Been thanked: 9 times
Post by MelvinsArmy »
This should have been posted in the BST forum.
You'd have been better off listing the parts you don't need. It would have been a much shorter list. :lol:
eddy
Post by eddy »
thank guys
i know its a shat load of parts i need , i was going post it in BST but i cant , i cant get in and i get my brother [ outside ] to do all my stuff on ebay as i dont hav a c/card , i try and find what i can get and if they sent to australia as well i save up what $$$$$$$$$$$ i can and get him
to do da deal for me .
Asso_man , if you can give me a price on the complete gold tub + postage to australia as well
i will do the deal with you . if you can email me at [email protected]
thanks guys for all your help its hard to find parts over here i found some parts but they are parts i do need but i still got then anyway.
I thank you all very much, thanks guys , eddy
Asso_man!
Post by Asso_man! »
Ok, I'll email you with some pics, price and shipping quote to Australia soon... :wink:
Users browsing this forum: User avatarhowsyouraspen and 5 guests
