Moderators: scr8p , klavy69
Posts: 16816 Joined: Tue Feb 07, 2006 9:46 pm
Has thanked: 36 times
Been thanked: 1319 times
7
Post
by scr8p » Mon Jan 23, 2023 7:47 am
Other than being shorter, so you can't run the aluminum wheel spacer between the pin and hub like the B4, they should be the same.
JosephS
Posts: 1874 Joined: Thu Mar 23, 2017 5:31 pm
Has thanked: 1245 times
Been thanked: 640 times
Post
by JosephS » Mon Jan 23, 2023 11:11 am
scr8p wrote: ↑ Mon Jan 23, 2023 7:47 am
Thanks. I only saw the part number differences after I bought a set of axles. Would I just need some shims to run pins on that setup?
7
Post
by scr8p » Mon Jan 23, 2023 11:49 am
So you have the B4 axles?
Yeah, you'll just have to add more shims. Or find the proper aluminum spacers.
JosephS
Post
by JosephS » Mon Jan 23, 2023 3:37 pm
scr8p wrote: ↑ Mon Jan 23, 2023 11:49 am
Opposite I have b4 bones and the customwoks axles. I'm gathering the parts for a b4 build.
RC10th
Posts: 4761 Joined: Sat Feb 16, 2013 9:51 am
Has thanked: 52 times
Been thanked: 1548 times
Post
by RC10th » Mon Jan 23, 2023 6:56 pm
Ideally you'd want the longer B4 axles and the #9608 spacer.
Not sure what custom works has but alternatively you could use these from Jeff which is a readily available replacement for the #9608. Mind you the spacers won't work with the shorter axle.
https://www.ebay.com/itm/303748279630
Last post by broodenburg
Fri Dec 05, 2014 4:26 am
Last post by 73rscamx
Thu Mar 28, 2013 8:59 am
Thu Apr 25, 2013 6:59 am
Last post by RC104ever
Sat Dec 22, 2012 9:52 pm
Mon Nov 25, 2013 10:55 am
Last post by MOmo
Thu Jun 18, 2009 5:35 pm
Last post by DaveM
Fri Dec 23, 2016 5:04 pm
Last post by Asso_man!
Fri Jun 13, 2008 6:31 am
Users browsing this forum: Amazon [Bot] and 7 guests
