Ayk Question ?-
Ayk Question ?-
I have been restoring this AyK Buffalo, i have noticed this that no other Ayk ,That I have seen has this front suspension set up this way the upper mouts are set back and longer then the other buggys i have seen with this simular chassis design. Does any body know anything that could shed some light, I was wondering if this was the older version of the buggy. I have attached some pics to help describe what i'm talking about?
- Attachments
- DSC06443.JPG (143.92 KiB) Viewed 918 times
- DSC06442.JPG (151.56 KiB) Viewed 918 times
- Asso_man!
- Has thanked: 40 times
- Been thanked: 82 times
Re: Ayk Question ?-
I think you mounted the front drive train the wrong way, I have restored a AYK Boxer, which has exactly same chassis, just a different body.
The upper links are supposed to attach in front of the monoshock, not at the rear...
Have a look here: http://www.rc10talk.com/viewtopic.php?f=5&t=3049&start=0
Come and visit the stable
Re: Ayk Question ?-
i have noticed that the upper threaded rod that adj.'s the camber is longer on your's and the ball end alum. mounts on your chassis are shorter then mine.
Re: Ayk Question ?-
also the front sway bar has is mounted to the shorter mounts in my pictures , as my longer posts are not drilled and tapped to hold the sway bar as the little ones are.
- 3161 Views
Last post by TomEG
- 1838 Views
Last post by Ayk Viper
- 363 Views
Last post by Dangeruss
- 1994 Views
Last post by Mr. ED
- 1425 Views
Last post by murphy3428
- 1628 Views
Last post by scootmike
- 1902 Views
Last post by saga101
- 3642 Views
Last post by Wahrsuul
