Ideas on repairing a jrx2 chassis plate
Toyotachris1982
Has thanked: 17 times
Been thanked: 13 times
Post by Toyotachris1982 »
Hello All! I have a jrx2 plate chassis and it has some small nicks on the edges and ideas on a product or method to repair them for a shelfie. Also maybe a topcoat that can have the same sheen as the original?
Has thanked: 2605 times
Been thanked: 2978 times
Re: Ideas on repairing a jrx2 chassis plate
Take a look at the chassis repair here:
https://www.rc10talk.com/viewtopic.php?f=35&t=46632
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Post by JosephS »
Toyotachris1982 wrote: Fri Nov 18, 2022 11:45 am Hello All! I have a jrx2 plate chassis and it has some small nicks on the edges and ideas on a product or method to repair them for a shelfie. Also maybe a topcoat that can have the same sheen as the original?
I was taking a look at the thread and a 2k epoxy primer was used. Typically a can of 2k needs to be used all at once. I found eastwood has a product they call Duraspray that can be shelved and reused. I used the clear coat from this line and it turned out good. It may be worth checking out the primer for your project.
https://www.eastwood.com/eastwood-2k-duraspray-epoxy-primer-two-component-aerosol-can.html
BattleTrak
Has thanked: 1153 times
Been thanked: 624 times
Post by BattleTrak »
CA/Super glue is what I use to repair edges and chips. I just repaired the tail on this JRX2 chassis. I went over the area with a black Sharpie, built up a few layers of glue then just lightly sanded to smooth and knock the shine off of the glue. I didn’t go too crazy making it perfect because I plan to run this one, but it looks a lot better.
-Brad
Toyotachris1982
Yeah that does look good! Thank you for the good info
Return to “Losi Forum”
