What diameter piano wire for 1/10 stock car wing?
GeneralZod
Has thanked: 150 times
Been thanked: 162 times
Post by GeneralZod »
What size piano wire is everyone using for 1/10 wing mounts? What size came with Bud's wing kits? I have 2mm but should I use 1.6mm? Any tools that would work bending this stuff?
Re: What diameter piano wire for 1/10 stock car wing?
I typically use .078, unless I can't get it through a particular wing mount. Then I'll use .062.
GeneralZod
scr8p wrote: Wed Nov 16, 2022 5:20 pm I typically use .078, unless I can't get it through a particular wing mount. Then I'll use .062.
Thanks. Any advice on bending tool? I have a bench vise but not sure I can achieve decent results with it.
I just use pliers.
Has thanked: 268 times
Been thanked: 2094 times
scr8p wrote: Wed Nov 16, 2022 6:40 pm I just use pliers.
Same here.
I use long lineman's pliers. They have plenty of leverage and the jaws are good for forming square edges. They also have good cutting edges.
Has thanked: 2604 times
Been thanked: 2977 times
For my last wing I used K&S metals 87131
Tang
Has thanked: 49 times
Been thanked: 73 times
Post by Tang »
Frankentruck wrote: Thu Nov 17, 2022 9:31 am For my last wing I used K&S metals 87131
Thanks, I'll try this for my next wing.
I get 0.062 music wire from the LHS. Usually three pieces, three feet long for a few dollars.
