XX / XXT Transmission Braces
Does anyone know if the XX transmission braces with the "ears" or "fingers" on them give any extra strength or rigidity to the chassis or transmission compared to the simple little rectangular braces? This will be for a runner build with a modern motor. If the eared braces help anything there are some repros on ebay that I can pick up. If they don't do much I have one of the old rectangular tab styles I can use. Thanks!
- RogueIV
- Has thanked: 2140 times
- Been thanked: 1100 times
Re: XX / XXT Transmission Braces
I don't have any actual experience with the XX platform but it appears that the one with the fingers would have a lot more surface area to brace the transmission as well as triangulating the support to the chassis helping mitigate rear flex.
Thanks for the reply. It seems the ears will need to be in full contact with the bulkhead to be a benefit so I think I will use one and just make sure of the contact and add some material if need be.
- Regular Member
- Been thanked: 4 times
I have only ever broken the ears off the transmission case just behind the holes that screw to the bulkhead. I don't believe either brace really solves that problem (unless others are suffering different failures to me).
What I have done is cut a piece of fibreglass/carbon that covers the holes in bulkhead and extends rearward all the way until the transmission angles up.
My buggy has done lots of silvercan racing and not failed like this.
My XXT has broken tabs and I have a plate over the top with some self tappers into the case. It has done thousands of brushless laps like this and is and still going strong. So whatever way you go, even if you do break the ears off it is cosmetic damage only and a nice carbon square will hide it.
- 703 Views
Last post by OG RC10T
- 1224 Views
Last post by markt311
- 952 Views
Last post by therigliveson
- 1498 Views
Last post by Erich Reichert
- 36 Replies
- 7725 Views
Last post by shoman24v
- 1110 Views
Last post by radioactivity
- 71 Replies
- 7019 Views
Last post by ireg
- 1376 Views
Last post by Beatnik
