BATTERY POWER CONNECTOR PINS 652 Team Associated
- Has thanked: 1243 times
- Been thanked: 639 times
Is there an generic alternate to, or cheap source of, BATTERY POWER CONNECTOR PINS 652 Team Associated?
- morrisey0
- Has thanked: 87 times
- Been thanked: 1853 times
Re: BATTERY POWER CONNECTOR PINS 652 Team Associated
Are they not just bullet connectors? From the 12L manual, it is hard to determine if they are specific pins for a plug or just bullets.
- Has thanked: 1129 times
- Been thanked: 3919 times
I assume you are asking about the motor connector. That is a simple AMPS 2 pin and can be found at Mouser, Digikey and other electronics shops.
https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1-480319-0/15662
I'm interested in the battery connector. It looks like a way to solder on bullet connectors to nimh cells. They look like they were used around the time of the original worlds and the t2.GoMachV wrote: ↑Tue Aug 09, 2022 9:26 pm I assume you are asking about the motor connector. That is a simple AMPS 2 pin and can be found at Mouser, Digikey and other electronics shops.
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
Have you checked out valkyriercmotorsports? They seem to have the 652 bullet connectors.
Or a 4mm bullet connector set.
Chuck
Chuck
I didn't check there. Thanks for the link. Looking at the picture of the actual plugs I'm going to have to read up on how they attach to the cells.radioactivity wrote: ↑Thu Aug 11, 2022 12:51 pm Have you checked out valkyriercmotorsports? They seem to have the 652 bullet connectors.
Chuck
These look to me to be the standard female bullet connectors which I already have in my parts box.
vs
The manual pictures aren't clear on what the solder connection looks like for the 652 connector. This is from the Worlds manual the T2 manual is slightly different.
- jcwrks
- Has thanked: 171 times
- Been thanked: 393 times
The Reedy 652's in your pic show both male and female connectors in the pack.
The TX SKUNK
Seeing those instructs helps quite a bit. These appear to be standard bullet connectors.
- 1355 Views
Last post by kaiser
- 852 Views
Last post by paul
- 1091 Views
Last post by TZona
- 796 Views
Last post by jcwrks
- 6087 Views
Last post by DHood
- 883 Views
Last post by GeneralZod
- 740 Views
- 1168 Views
Last post by Lonestar
