Kyosho M2.6 nuts
RichieRich
Has thanked: 39 times
Been thanked: 25 times
Kyosho M2.6 nuts
Post by RichieRich »
Guys, I'm looking for a source for M2.6 nuts. Kyosho uses this size for some of the suspension link connections. Of course, I can buy an OEM pack of 10 for $10, but that just seems silly. I've found some here:
https://www.mcmaster.com/nuts/hex-nuts/thread-size~m2-6/
These appear to be plain with a zinc coating. Has anyone found any that are black oxide like the originals?
Has thanked: 270 times
Been thanked: 2095 times
Re: Kyosho M2.6 nuts
None that are any cheaper. The 2.5 is much more common.
That is an odd size. It is used on the endbells of many brushed motors, which finding various length screws is bad enough.
Finding a tap and rethreading some 2.5 or 2-56 nuts might be an option.
R6cowboy
Has thanked: 884 times
Been thanked: 905 times
Post by R6cowboy »
I had the same concern when starting my Kyosho Pro-XRT build. I ended up deciding the heck with 2.6mm hardware and went with 3mm. I just enlarged the holes to accept the 3mm ball ends and screws. Just throwing out another idea.
-Jerry-
radioactivity
Has thanked: 384 times
Been thanked: 618 times
Post by radioactivity »
If looking for
Then https://www.amainhobbies.com/kyosho-2.6x2.0mm-steel-nut-10-kyo1-n2620/p169844 for $5.
Chuck
Return to “Kyosho Forum”
