Gold pan parts help
DodgeDude99
Gold pan parts help
Post by DodgeDude99 »
I just bought a used gold pan & I am trying to recreate what I had as a kid in the lates 80’s/early 90’s.
I swapped out the 32 pitch gears in the trans for 48, I don’t remember who made the kit?
Also on the A-arms, I had black arms, who all made arms for these cars back then so I could narrow it done by looks?
And lastly, the dish wheels.
Thanks
Shawn
clm
Has thanked: 100 times
Been thanked: 205 times
Re: Gold pan parts help
Post by clm »
If you had black narrow arms perhaps they had been dyed black?
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
Has thanked: 2605 times
Been thanked: 2979 times
Welcome. Good luck on your rebuild project. Thorp 48 pitch gear conversion is most likely what you had, and probably Andy's arms in black. Dish wheels could have been Pro-line or Associated. Those are options for used parts. For new, JConcepts has fronts. For rears it will depend on whether you are using 1/4" or 3/16" rear axles.
DodgeDude99
Thorp I forgot about them.
I did dye the white parts black but I replaced the arms with aftermarket.
So many of the brand names that were popular back then seem to be gone or forgotten about.
Do any of the RC10T or GT or even the Worlds car fit as far as the Stealth trans?
Has thanked: 269 times
Been thanked: 2095 times
DodgeDude99 wrote: Tue Jul 19, 2022 10:08 am Do any of the RC10T or GT or even the Worlds car fit as far as the Stealth trans?
The Worlds and 10T transmission is the same as the Team Car. Other than drilling new holes, it's a direct fit. Factory Works has the drill template.
The GT input shaft, slipper, and idle gear is the same as the above.
Worlds re-re used a different case, idle gear, input shaft, and slipper assembly. The newer shaft and slipper will swap to early transmissions. I'd avoid the re-re case and idle gear.
DodgeDude99
What’s the issue with the re-re case & idler?
Been thanked: 3919 times
DodgeDude99 wrote: Wed Jul 20, 2022 8:56 am What’s the issue with the re-re case & idler?
First, all Chinese build. Then swapped for a USA case leaving the Chinese idler. Last is with the USA case and idler.
https://youtu.be/3W1f9dyMFqI
The USA case and idler spin very freely with no break in. The Chinese idler appears to be slightly oversize creating a lot of drag. The case must be swapped to use the USA idler since they changed the location of the bearing for the idler on the Chinese set.
What he said.
Users browsing this forum: No User AvatarAhrefs [Bot], No User AvatarBing [Bot] and 8 guests
