Lunchbox gear noise
Lunchbox gear noise
Was driving my Lunchbox last night and noticed noise coming from the gearbox .Not a grinding sound but growling , it happens in both forward and reverse . I thought it was just the tires on the floor but I picked it up and spun the rear wheels and the sound was still there the weird thing is when I spin the wheels and rotate the truck side to side the sound gets louder on the passenger side . Could this be a grease issue in the gear box ?
- silvertriple
- Has thanked: 750 times
- Been thanked: 1324 times
- Has thanked: 1153 times
- Been thanked: 624 times
Re: Lunchbox gear noise
Only one way to find out..take it apart and inspect. You could start by taking the motor off and checking the pinion & counter gear and see if there’s any debris floating around.
-Brad
The bearings were new . Ya I suppose I will take apart was trying to avoid that but in I go.
- silvertriple
as mentioned : only way to know for sure is to have a look inside. That said, a new bearing can fail (sometimes (sh) it happens, and generally would be even the most difficult to reach, just because otherwise there would be no fun
Ya very true
A sport tuned motor would not due any damage right ? Well in I go I will report back.
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2095 times
If you are using the original Tamiya pinion, replace it with a higher quality one. The original will wear quickly and can damage other gears and throw metal particles through the transmission.
Ok at the risk of sounding stupid what exactly am I looking for, all i see is looks like black grease not sure where it is from .Possible pinion rubbing somewhere but can't tell no wear marks , confused
- Has thanked: 2759 times
- Been thanked: 2250 times
Start with the pinion , has the set screw come loose ? its also possible with a very old Tamiya pinion that its simply worn out and its skipping on the spur gear , they are made of the softest aluminium in the world
next has it got bushings or bearings , if its got bearings check that they are all running smoothly , it really could be a bad bearing .
Ya still using original pinion it's all I had . Where do I find an upgrade ?
Ebay is easiest or if you have a local hobby shop , your looking for an 18 tooth 0.8 mod pinion , steel is best . you better count the teeth on it to be sure as I'm just guessing its the same as the Hornet .
Just looking to keep stockish one of the upgrades was the sport tuned motor, bearings (full) and a HD steering servo. Oh ya and Yeah racing oil filled dampers. How much grease do you need in the gear box any way.
Well did a total tear down to find out that for the most part everything looked good other than a heck of alot of grease in the diff spur gear the counter gear bevel gears every where gummed up good. So going to give her a really good clean and rebuild .
- Frankentruck
- Has thanked: 2605 times
- Been thanked: 2980 times
Just to dog pile on, it would be good to get a steel pinion gear. Even brass is better than aluminum. It might not be your problem right now, but when worn the aluminum gear will damage the other gear it meshes with.
The gears just need enough lube to not be dry. Extra will usually get flung off.
- 3389 Views
Last post by losiXXXman
- 1327 Views
Last post by bird
- 577 Views
Last post by tamiya
- 1019 Views
Last post by tommy217xxx
- 1534 Views
Last post by badhoopty
- 911 Views
Last post by pmathews924
- 782 Views
Last post by vintage88
- 45 Replies
- 2419 Views
Last post by Dangeruss
