Urethane clear coat spray cans
- Has thanked: 1203 times
- Been thanked: 598 times
Hey all,
This is venturing into 1:1 paint. It looks like to properly finish out my carbon fiber chassis I will need a clear coat.
I have read that for the coating of epoxy made carbon fiber that urethane clear coat is the preferred the right product. Since I don’t have a compressor or spray gun I was going to use a canned version.
Has anyone clear coated carbon fiber? If so do you have any recommendations on brands or products?
Any process tips?
Thanks all!
Any process tips?
Thanks all!
- TheDiamondOne
- Has thanked: 1980 times
- Been thanked: 547 times
Re: Urethane clear coat spray cans
Yes. I would go with The Eastwood Co. Great products. Make sure chassis is cleaned well and scuffed with scothbrite prior to painting.
If I am wet-sanding the epoxy can I just clean as is, or do i need to scuff with scotch-brite as well?TheDiamondOne wrote: ↑Mon Jun 06, 2022 5:26 pm Yes. I would go with The Eastwood Co. Great products. Make sure chassis is cleaned well and scuffed with scothbrite prior to painting.
Thanks for the nod towards Eastwood. I have been reading a little about 1k vs 2k paints. It sounds like 2k rattle cans are a single use affair (within 24 hours), but a much better paint. 1k paint can stored and reused over time.
Does that sounds right?
I went to the product link for the eastman 2k clear gloss
https://www.eastwood.com/eastwood-2k-duraspray-clear-coat-aerosol-paint.html
It looks like this product is specifically designed to avoid the issue I am concerned about
Just ordered a canThis standard aerosol can contains the clear and activator, but the activation doesn’t occur until they are sprayed out of the can and hit the air and become a highly durable two component coating, just like you would typically mix and spray out of a paint gun.
[*]Unlimited Pot Life
- Has thanked: 40 times
- Been thanked: 34 times
Seconded on Eastwood. I use the satin clear urethane, works great. It's a bit costly because the can kicks in 48 hours, so if you can plan to do more than one project at a time you can get a little more bang for your buck.
I'll let you know how my projects works out but it looks like they have a new product for the 2k coats.
The older one had a separate chamber for catalyst. The new one looks like the catalyst is activated via air or moisture, so the whole can doesn't have a pot life like the older product. It seemed worth a try.
- TheDiamondOne
Yes the 2k stuff has a a day shelf life but way more durable. It never hurts to clean things as much as possible after sanding. Laquer thinner is real good.JosephS wrote: ↑Mon Jun 06, 2022 6:26 pmIf I am wet-sanding the epoxy can I just clean as is, or do i need to scuff with scotch-brite as well?TheDiamondOne wrote: ↑Mon Jun 06, 2022 5:26 pm Yes. I would go with The Eastwood Co. Great products. Make sure chassis is cleaned well and scuffed with scothbrite prior to painting.
I picked up the Eastwood 2k gloss clear. I'm just about at the point where I am about to apply the clear coat.
I am applying it over epoxy resin. Do I need to wait for the epoxy to fully cure, or is sanding hard enough?
I think it takes about 7-11 days for the epoxy to fully cure, but it's sanding hard after 3 days.
How long does the 2k clear take to cure? I have heard that it should be applied in 3 thin coats at the same time to get full coverage, but prevent runs. After that I would sand, then polish then I would be done.
- 20 Replies
- 2272 Views
Last post by Asso_man!
- 478 Views
Last post by Brendan2904
- 1648 Views
Last post by Lowgear
- 1391 Views
Last post by silvertriple
- 544 Views
Last post by adam lancia
- 1635 Views
Last post by DMAT
- 1602 Views
Last post by cybercrxt
- 1056 Views
Last post by 1911Colt
