pit board/setup board what features should they have
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Post by JosephS »
I was thinking that I should make a setup board for myself, but I don't have any experience using them.
Does anyone here use one? Are there anything that make one better to use?
what's a good size for 1/10 buggies and Stadium trucks? 16"x20" seems to be what I see for 1/10.
I'm not worried about weight since it's going to spend most of it's time living at my house. I am considering laminated particle board or plywood for the surface.
I have a camber and ride height gauge so I'd just use them
most boards I see are black, but would white be a better choice?
features I have seen
  • embedded magnets along the edges- seems pretty great for keeping steel parts in place.
  • A measurement sticker for x and y axis
  • lightup- how is that useful? wouldn't it make it hard to see what you are working on in the dark?
  • Feet- is it be handy to have a way to level the board? I have only seen one board with feet
  • bubble levels- Goes along with feet
Stuff I haven't seen
  • board rim- since a bunch of parts are plastic or titanium wouldn't it make sense to have a way to keep them on the board?
  • Tool holes or slots- should I not be wrenching on a setup board
Has thanked: 269 times
Been thanked: 2094 times
Re: pit board/setup board what features should they have
If you don't have benches available, I'd look at a folding table and rubber pit mat.
Something like this would be simple and easily portable.
https://www.amainhobbies.com/traxxas-rubber-pit-mat-91x50cm-tra3426/p1216228
The table and mat could also be adapted to different situations.
Magnetic strips are nice and easy enough to add.
For travel, I'd probably keep my tools separate. The open top bags (semi-rigid) are nice and easy to find.
Maybe consider one of the bucket caddys, the ones that add pouches and pockets to the inside and outside of a 5 gallon bucket.
There are also bucket seat lids, giving you storage and somewhere to sit.
BattleTrak
Has thanked: 1153 times
Been thanked: 624 times
Post by BattleTrak »
Bonus points if you include a 4 corner weight scale!
-Brad
JosephS
Post by JosephS »
BattleTrak wrote: Fri May 20, 2022 10:34 pm Bonus points if you include a 4 corner weight scale!
Do you have an example of that? I can't think of a simple way to do that.
BattleTrak
-Brad
JosephS
Post by JosephS »
I was thinking how to get that into a board. I see how it makes sense as a separate system. Right now I think a stiff board that I can level will help me set camber and caster the same across each wheel.
SoulKage
Post by SoulKage »
This may be an off-topic question. With the data from the 4-corner system, it seems to me you're very limited on adjusting existing weight. You would have to add weight to even things out.
JosephS
Post by JosephS »
SoulKage wrote: Thu May 26, 2022 3:54 am This may be an off-topic question. With the data from the 4-corner system, it seems to me you're very limited on adjusting existing weight. You would have to add weight to even things out.
you could also move components around the chassis, like adjusting battery position.
Lowgear
Has thanked: 121 times
Been thanked: 795 times
Post by Lowgear »
You are correct. The adhesive backed lead wheel weights for 1:1 cars are what's commonly used.
Users browsing this forum: No User AvatarAhrefs [Bot] and 3 guests
