Hello all,
I'm looking at getting different shocks to fit my goldpan rc10 DS conversion.
Will the tc7.1 shocks fit the rc10DS, or are they too short?
It seems that the stroke length is very close between the ds .35" and the tc 7.1 8mm . I don't know about the shock bodies, are the lengths and caps compatible?
It seems that the 7.1 shocks use an 11mm spring, and are bigger than the vcs 1/2/3 shocks and the tc3-7 shocks.
It seems that the VCS1/2/3 shocks should be a direct drop in. Would the tc3-7 shocks be the same
can TC 7.1 shock fit an rc10 DS
- Has thanked: 1264 times
- Been thanked: 649 times
- juicedcoupe
- Has thanked: 273 times
- Been thanked: 2112 times
Re: can TC 7.1 shock fit an rc10 DS
The DS uses 0.56 bodies and 0.35 shafts.
Thanks for that I am trying to figure out how the modern shocks would fit
https://www.associatedelectrics.com/factoryteam/parts/details/31745-ASC31745-ft_11x9_mm_fox_r_shock_bodies_genuine_kashima_coat_ss_threaded/
11mm is .43 inches and 9mm is .35
does that mean the shock body is .43(11mm) long and has a final stroke of .35 (.9mm)? That 1/8" doesn't seem like it should break things.
- juicedcoupe
The shock body is the same as the short arm RC10 fronts, with shorter shafts.
I think that the DS is ~2.25", eye to eye.
- 804 Views
Last post by lexus-5
- 945 Views
Last post by torrnado_firemagikk
- 2272 Views
Last post by rctenracer
- 648 Views
Last post by phoenix
- 559 Views
Last post by Asso_man!
- 3225 Views
Last post by tommy2c
- 484 Views
Last post by shredderboy
- 1604 Views
Last post by limestang
