Since I was switching out the outdrives in my RC10T4 FT from the regular units to the lightweight outdrives, I decided to weigh the three different AE outdrive options that were for the various versions of the B4, T4, SC10 and GT2.
Associated part numbers:
- 1766 FT Lightweight Outdrive Set (uses 3/8" x 5/8" outdrive bearings). Compatible with transmission case part # 9574.
- 7667 & 7668 Diff Outdrive Hub, right & left (uses 3/8" x 5/8" outdrive bearings). These were used in the original version of the B4, T4, SC10 and GT2. Compatible with transmission case part # 9574.
- 9852 SC10 FT Ball Diff Outdrives (uses 10mm x 16mm outdrive bearings). These were used in the B4.1 & 4.2, T4.1, T4.2 & T4.3, and later SC10s. Compatible with transmission case part # 9826.
Part # 1766
Part # 7667 and 7668
Part # 9852
Associated outdrives for B4/T4/SC10- Lightweight vs Regular
Forum rules
- 1356 Views
Last post by LTO_Dave
- 910 Views
Last post by mikedealer
- 757 Views
Last post by dinglem
- 44 Replies
- 6176 Views
Last post by scoobyrs25
- 2035 Views
Last post by golaebob
- 2469 Views
Last post by GJW
- 644 Views
Last post by chophead69
- 1082 Views
Last post by RPMfieldtester
