Tamiya Sand scorcher ball diff
- Been thanked: 81 times
Hello . I am getting ready to assemble a sand scorcher kit. Any comments on is it worth installing the ball diff upgrade #54897. Thanks.
- finman
- Has thanked: 4 times
Re: Tamiya Sand scorcher ball diff
Really depends on where you intend to run it.
If it's on the beach or any thing loose probably better without the diff. especailly if you want rooster tails.
If on hard surfaces, tarmac etc the diff will help reduce it rolling as much and hopefully reduce body damage!!
And this is how it starts
- Has thanked: 2759 times
- Been thanked: 2250 times
as above , it works on hard surfaces but they tend to come loose as the adjustment is not on a nylock nut as usual but has a screw with dry locktight , you need additional locktight on the screw or it works loose and you loose drive .
- 2937 Views
Last post by civilguy
- 170 Replies
- 18245 Views
Last post by GreenBar0n
- 3409 Views
Last post by Tobbe70
- 962 Views
Last post by GRRacing
- 460 Views
Last post by Dangeruss
- 2859 Views
Last post by dsmith
- 1988 Views
Last post by shagrat69
- 47 Replies
- 8864 Views
Last post by KidAgain
