Hyperdrive conversation parts
Has thanked: 2606 times
Been thanked: 2980 times
This is probably a question that doesn't need asking, but there aren't any sources of hyperdrive belts and spur/pinion pulleys anymore are there?
Been thanked: 3919 times
Re: Hyperdrive conversation parts
The belts carry a SDP part number and SDP-SI is still around. However the belts were cut to a narrower width than I seen listed back when I looked at this- and it was a couple years back- but I suspect in quantity they could get them in the proper widths.
Link in this is dead anyway but part number might get you in the ballpark
Much appreciated. Do you think there's any hope of finding any pinion or spur pulleys, other than just watching eBay for pop-ups?
Has thanked: 1737 times
Been thanked: 1145 times
Frankentruck wrote: Fri Nov 05, 2021 10:11 pm Much appreciated. Do you think there's any hope of finding any pinion or spur pulleys, other than just watching eBay for pop-ups?
I'd go eBay, and keep your eyes open.... they do pop up every now and then. I was able to grab a set a decade or so ago, in a lot of other junk.... split it up and sold off the Hyperdrive parts, and somebody got to do good things with them.
Patience, I guess.... :roll:
cas22
Has thanked: 130 times
Been thanked: 249 times
Post by cas22 »
Hey I have been playing around with some belt drive units from Aliexpress
https://www.aliexpress.com/item/1005002345664360.html?spm=a2g0s.9042311.0.0.27424c4dLbzcDr
May be able to use some of these parts, im looking to adapt the slipper units for one of my builds, They also have a ton of drive belt pulleys which im sampling to fit on my Rocky conversion, but they are predominantly set up for 3D printers and you need to check the belt pitch and width.
Good luck
Users browsing this forum: No User AvatarBing [Bot] and 4 guests
