To Dye or Not To Dye
qctires
Post by qctires »
I just won a set of black Andys rear arms on ebay (have not received it yet) and I was asking myself if I should dye my RPM worlds arms. Any suggestions? I think it will look nice and leave the other AE parts stock. How about the blue parts (tubes, screws, shock caps)? Better in BLACK?
MelvinsArmy
Been thanked: 11 times
Post by MelvinsArmy »
If it was my car, I'd say no to dye and loose the blue parts. Blue aluminum is new school to me.
qctires
Post by qctires »
MelvinsArmy wrote:If it was my car, I'd say no to dye and loose the blue parts. Blue aluminum is new school to me.
That's possible...black tube or aluminun? The ESC will be a 410M1c NOVAK but the receiver will be that MICRO airtronics or an XXL Novak. I have no choice but to USE a 3PJS or my M8.
How about the Andys arms? They're black. I guess I'll just have to put it on the RC10 Graphite. I got this a few days ago. Not yet here thou.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ih=006&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=160044385361&rd=1&rd=1
Been thanked: 1319 times
i think you should leave the front end white, and give me the rear shocks. :wink: :)
qctires
Post by qctires »
scr8p wrote:i think you should leave the front end white, and give me the rear shocks. :wink: :)
hmmmn...makes sense... 8) :P :roll:
it sounds good to me. :wink:
qctires
Post by qctires »
scr8p wrote:it sounds good to me. :wink:
The MIPs that you have, is it long enough to fir the kit with the OEM wide arms?
badhoopty
Has thanked: 183 times
Been thanked: 157 times
Post by badhoopty »
i'd at least dye the arms black to match.
shodog
Been thanked: 91 times
Post by shodog »
my thought is since they have a little bit of use, dye them black. if they were pristine then I would leave them white.
qctires
Post by qctires »
How about the rears? My choices are...
1. Ansdys black rear arms
2. OEM dyed rear arms or leave it as is
3. If I use te Andys rear, what do I do with the Andys black fronts.
And I need an upper deck. I installed the GT tube holders but they are not year correct. No good.
you could get a pr. of rear rpm a-arms. that way you'd have rpm f & r.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEU95&P=M
badhoopty
Post by badhoopty »
qctires wrote:How about the rears? My choices are...
best thing would be to pick up a rear rpm widearm kit to match the front.
qctires
Post by qctires »
...and I have a feeling you have one... 8)
Why is it called a WIDE ARM rear? Is the configuration different from the stock?
you notch out the where the a-arm mounts are, and move them in, closer to the trans. that way you'll still have the same track width with the longer a-arm.
badhoopty
Post by badhoopty »
yea, the arms mount closer together on the chassis so they are longer without increasing overall width. (you gotta narrow the rear of the chassis, and they have special a-arm mounts that hug the stealth)
rears pop up on ebay every so often.
Users browsing this forum: User avatarSwath and 3 guests
