RPM ball cups rubbing
Demonkey
Has thanked: 4 times
Been thanked: 9 times
Post by Demonkey »
Does anyone else that is using the RPM ballcups have issues with them rubbing on the inner wheel when it is turned ? I’m using standard inline axles. I realize I can adjust the end point trim to prevent this but it affects the turning radius. I know the worlds car axles would also resolve the issue but I don’t like the extra width on the front, it makes the truck look odd to me. What are your thoughts?
Has thanked: 269 times
Been thanked: 2094 times
Re: RPM ball cups rubbing
I just checked one of my 10T's with original wheels. Even the AE ball cups (newer type) rubbed a little at full lock, but they are a little smaller than the RPM cups.
Demonkey
Post by Demonkey »
juicedcoupe wrote: Fri Aug 27, 2021 9:21 pm I just checked one of my 10T's with original wheels. Even the AE ball cups (newer type) rubbed a little at full lock, but they are a little smaller than the RPM cups.
Yes, I have a few 10T trucks and the stock ball cups are super close. I think the brand of wheel may also play a small part. I love the look of the white ball cups on the vintage truck with white parts, however the rubbing is a bugaboo. My best option is going to be to adjust the endpoints and live with a larger turning radius.
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Post by JosephS »
Demonkey wrote: Fri Aug 27, 2021 9:13 pm Does anyone else that is using the RPM ballcups have issues with them rubbing on the inner wheel when it is turned ? I’m using standard inline axles. I realize I can adjust the end point trim to prevent this but it affects the turning radius. I know the worlds car axles would also resolve the issue but I don’t like the extra width on the front, it makes the truck look odd to me. What are your thoughts?
I use the smaller cups in a few areas where rubbing happens.
RPMfieldtester
Has thanked: 83 times
Been thanked: 76 times
Post by RPMfieldtester »
I always ran the RPM ball cups and never had an issue with the rubbing...the strength of the RPM cup outweighed any rubbing...plus, as mentioned, end point adjustments and didn't need to drive at full lock much...
Return to “RC10 Truck Forum”
Users browsing this forum: No User AvatarAhrefs [Bot] and 3 guests
